Strange Trajectory Planner behaviour
gnrules
Re: Strange Trajectory Planner behaviour
Post by gnrules » Fri Mar 12, 2021 10:40 am
I added 4th decimal digit to my code and now it is very smooth without any dicontinuity even in limited velocity segments.
You were right about truncation/rounding error relative to decimal digits in g-code.
It was something that we would experiment because we use 0.5um glass scales, but now it is mandatory!!
Thank you for tour support.
Best regards
Giancarlo
GabrielR922
Post by GabrielR922 » Mon Mar 15, 2021 6:10 pm
Hi Tom and Giancarlo.
Let me see if I understood.
Even if I have a precision of ~0.01mm, it's best to post the code with 3 decimal cases? ig: 0.001?
Is there a tutorial to how plot the data like both you are doing?
Gabriel
Post by TomKerekes » Mon Mar 15, 2021 11:45 pm
Hi Gabriel,
Yes it a good idea to have numerical resolution an order of magnitude better or more than the precision you are trying to achieve.
The charts I posted regarding the GCode segment lengths and angles were simply created by editing the GCode to remove non numeric characters (GXYZ) then pasting into Excel using text to columns. Then I calculated the Deltas. From deltas I calculated lengths and angles. Then deltas of those. I've attached it.
To capture data within KFLOP you might read the wiki here.
GCodeNoise.xlsx
(39.9 KiB) Downloaded 967 times
