The text documents that the plots downloaded as exceeded the maximum attachment size so I copied the text into word documents. Please let me know if this will not work and how to go about getting the files to you.
Scott
Fanuc DC motor drives
Scott Pancheau
Re: Fanuc DC motor drives
- 0 Plot with 3 inch move.docx
- (516.31 KiB) Downloaded 1080 times
- 0 Axis Plot with about half inch move.docx
- (327.49 KiB) Downloaded 1094 times
Hi....Present day drives don't utilize the tachometer, there are drives out there that should work. I trust Larkin is building up a higher current drive.
You should supplant the tach with encoders. DC engines are the most adaptable out there as they needn't bother with outer compensation.
