Beginners
Re: Beginners
Post by TomKerekes » Sun Dec 15, 2019 6:24 pm
Hi GS76,
Apologies, what do you mean the 5V and Rx are wrong, how should they be?
Rx is the input. It should be connected to KStep's AnalogOut. 5V should be connected to KStep's AnalogVcc.
I have the DC power connected through the relay to and then the relay to the motor controller. The spindle uses a 7.5V DC motor supply.
This isn't clear. That's why it is better to use a diagram. The DC current would be very high (28Amps?) and more than the relay's rating. You should probably switch the 120VAC to the supply instead.
Please update the diagram.
GS76
Re: Beginners
Post by GS76 » Mon Dec 16, 2019 4:59 am
Thank you, Tom.
I will review and get back to you regarding the relay wiring.
