What would cause direct FPGA I/O to break?
SJHardy
Re: What would cause direct FPGA I/O to break?
Post by SJHardy » Mon Jun 01, 2020 9:07 pm
BigThread7 compiles and loads OK, but when I execute it there is no console print. If I comment out the array definition and change to a different printf, it works.
I could not see any obviously bad addresses in the load.
Attached linker files. I'll download the latest release and try it out.
SJH
linkerfiles.zip
(5.05 KiB) Downloaded 229 times
SJHardy
Post by SJHardy » Mon Jun 01, 2020 9:12 pm
PS:
I did notice there are some comments in cload_cinit() which are tagged with 'tktk':
if (temp == 0) // tktk skip 0 length pads
Stepping through with the debugger, I did notice that temp would in fact be zero every other time through the main loop of that function. Not sure how that's supposed to work, but from a naive perspective I would not have expected it to take that branch so often.
SJH
SJHardy
Post by SJHardy » Mon Jun 01, 2020 9:59 pm
Found this thread re TI:
https://e2e.ti.com/support/tools/ccs/f/81/t/454222
So I added
i = i+7 & ~7; // SJH - align to 8
at the bottom of the loop in cload_cinit() and (lo and behold) it fixes my problem loading the supervisor. So I guess you should try it out on Windows too!
SJH
Post by TomKerekes » Tue Jun 02, 2020 3:49 pm
SJH,
You're a genius! It works in Windows also and allows your .out file to load and run in V4.33q. Will add to the next release.
