KMotion/KFLOP/Kogna Version 5.3.7 Released
This Version fixes several issues with the .NET KM_Axis and KM_AxisGroup Classes
Adds KMotionCNC Disable buttons capability from KFLOP/Kogna
KMotionCNC GViewer Setup Screen now allows mm/inch settings.
GCode Interpreter M48 and M49 supported to disable/enable overrides FRO and SSO
A number of new C Examples Added
A number of other fixes and features.
Please report any issues.
Complete Change List V5.3.7
Download
Re: KMotion/KFLOP/Kogna Version 5.3.7 Released
We really need additional cells in the tool table.
Tool length should consist of the main and additional cells, the values of which should be summed up. This way, the operator will not change and remember the original compensation value. He will only make adjustments to an additional cell. This reduces errors related to the human factor.
The same should be done with the tool diameter.
Hi Alexanders,
There haven't been other requests for this option. Its somewhat difficult as it changes the tool Table format and the Tool Table Screen. Some users might not appreciate the changes so it would need to be done as an optional, backward compatible manner. So then also a new option to select the mode. If you are willing to make the changes yourself in a backward compatible manner we will incorporate them.
