[1]
Please can you add the following Property for the next release: KM_Interpreter_SetupParams.DoRapidAsFeeds
I verified and you already implemented the needed interops in KMotion_dotNet_Interop.cpp
Just the .Net property using those is missing
My problem is that it seems that the Hardware FRO is not influencing so much the G0 speed, So I would like to have this functionality.
[2]
Please can you modify the following method KM_Interpreter.SetOrigin(int index, double x, double y, double z, double a, double b, double c)
=> save the Vars file when this SetOrigin method is called.
Remark: I use KMcontroller.CoordMotion.Interpreter.VarsFile to specify the location of this file.
Finally,
I'm actually evaluating a KOGNA (SN150 FYI) + KANALOG for replacing our actual CNC cabinets based on too expensive OMRON CK3E (DeltaTau PowerPMAC Ethercat) and for older customers proposing a retrofit of different DeltaTau PMAC & TurboPMAC (+-10V DAC) we installed in the last 20 years mainly in France and West Europe.
We provide a dedicated custom HMI based in .Net.
That's why I'm heavily testing the different possibilities of your .Net library to adapt our current HMI.
Thanks for your kind support.
Frederic
.Net library missing functionalities
Re: .Net library missing functionalities
Could you also confirm if any plans are in place to enhance .Net integration with more examples or documentation? This would be very helpful for developers working on custom HMIs.
I'm a software developer working on amazing projects.
