idk why lathe changes
Re: idk why lathe changes
No
You've included CSSJog.c and also pasted its contents. Only Include it.
You have 2 main() functions. There must only be one. main() is where the program starts. There can be only one starting place for a program.
Code is incorrectly indented making it hard to understand or read. Use Auto Indent to clean it up.
gotcha
Can grounding the E stop from the servo amp to the electronics case bring in noise?
getting some nice run off on Z axis in the Z negative direction only
even after the MaxFollowingError=5000 trips
X axis works great
X axis works great
anything else i should do to the init or is it runnable for spindle turning?
#include "MySpindleDefs.h"
#include "CSSJog.c"
int main() {
// X axis
ch0->InputMode=ENCODER_MODE;
ch0->Vel=80000;
ch0->Accel=5e+07;
ch0->Jerk=5e+07;
ch0->P=5;
ch0->I=0;
ch0->D=20;
ch0->FFAccel=0;
ch0->FFVel=0;
ch0->MaxI=200;
ch0->MaxErr=200;
ch0->MaxOutput=2000;
ch0->DeadBandGain=1;
ch0->DeadBandRange=0;
ch0->InputChan0=0;
ch0->InputChan1=0;
ch0->OutputChan0=0;
ch0->OutputChan1=0;
ch0->MasterAxis=-1;
ch0->LimitSwitchNegBit=0;
ch0->LimitSwitchPosBit=0;
ch0->SoftLimitPos=1e+09;
ch0->SoftLimitNeg=-1e+09;
ch0->InputGain0=1;
ch0->InputGain1=1;
ch0->InputOffset0=0;
ch0->InputOffset1=0;
ch0->OutputGain=1;
ch0->OutputOffset=0;
ch0->SlaveGain=1;
ch0->BacklashAmount=0;
ch0->BacklashRate=0;
ch0->invDistPerCycle=1;
ch0->Lead=0;
ch0->StepperAmplitude=250;
ch0->iir[0].B0=1;
ch0->iir[0].B1=0;
ch0->iir[0].B2=0;
ch0->iir[0].A1=0;
ch0->iir[0].A2=0;
ch0->iir[1].B0=1;
ch0->iir[1].B1=0;
ch0->iir[1].B2=0;
ch0->iir[1].A1=0;
ch0->iir[1].A2=0;
ch0->iir[2].B0=1;
ch0->iir[2].B1=0;
ch0->iir[2].B2=0;
ch0->iir[2].A1=0;
ch0->iir[2].A2=0;
// Z axis
ch1->InputMode=ENCODER_MODE;
ch1->Vel=80000;
ch1->Accel=5e+07;
ch1->Jerk=5e+07;
ch1->P=10;
ch1->I=0;
ch1->D=20;
ch1->FFAccel=0;
ch1->FFVel=0;
ch1->MaxI=200;
ch1->MaxErr=200;
ch1->MaxOutput=2000;
ch1->DeadBandGain=1;
ch1->DeadBandRange=0;
ch1->InputChan0=1;
ch1->InputChan1=0;
ch1->OutputChan0=1;
ch1->OutputChan1=0;
ch1->MasterAxis=-1;
ch1->LimitSwitchOptions=0x114;
ch1->LimitSwitchNegBit=11;
ch1->LimitSwitchPosBit=0;
ch1->SoftLimitPos=1e+09;
ch1->SoftLimitNeg=-1e+09;
ch1->InputGain0=1;
ch1->InputGain1=1;
ch1->InputOffset0=0;
ch1->InputOffset1=0;
ch1->OutputGain=1;
ch1->OutputOffset=0;
ch1->SlaveGain=1;
ch1->BacklashAmount=0;
ch1->BacklashRate=0;
ch1->invDistPerCycle=1;
ch1->Lead=0;
ch1->MaxFollowingError=5000;
ch1->StepperAmplitude=250;
ch1->iir[0].B0=1;
ch1->iir[0].B1=0;
ch1->iir[0].B2=0;
ch1->iir[0].A1=0;
ch1->iir[0].A2=0;
ch1->iir[1].B0=1;
ch1->iir[1].B1=0;
ch1->iir[1].B2=0;
ch1->iir[1].A1=0;
ch1->iir[1].A2=0;
ch1->iir[2].B0=1;
ch1->iir[2].B1=0;
ch1->iir[2].B2=0;
ch1->iir[2].A1=0;
ch1->iir[2].A2=0;
// A axis / spindle
ch2->InputMode=ENCODER_MODE;
ch2->Vel=300000;
ch2->Accel=80000;
ch2->Jerk=150000;
ch2->P=10;
ch2->I=0;
ch2->D=10;
ch2->FFAccel=0;
ch2->FFVel=0;
ch2->MaxI=200;
ch2->MaxErr=1e+06;
ch2->MaxOutput=2000;
ch2->DeadBandGain=1;
ch2->DeadBandRange=0;
ch2->InputChan0=2;
ch2->InputChan1=0;
ch2->OutputChan0=2;
ch2->OutputChan1=0;
ch2->MasterAxis=-1;
ch2->LimitSwitchNegBit=0;
ch2->LimitSwitchPosBit=0;
ch2->SoftLimitPos=1e+30;
ch2->SoftLimitNeg=-1e+30;
ch2->InputGain0=-1;
ch2->InputGain1=1;
ch2->InputOffset0=0;
ch2->InputOffset1=0;
ch2->OutputGain=1;
ch2->OutputOffset=0;
ch2->SlaveGain=1;
ch2->BacklashAmount=0;
ch2->BacklashRate=0;
ch2->invDistPerCycle=1;
ch2->Lead=0;
ch2->StepperAmplitude=20;
ch2->iir[0].B0=1;
ch2->iir[0].B1=0;
ch2->iir[0].B2=0;
ch2->iir[0].A1=0;
ch2->iir[0].A2=0;
ch2->iir[1].B0=1;
ch2->iir[1].B1=0;
ch2->iir[1].B2=0;
ch2->iir[1].A1=0;
ch2->iir[1].A2=0;
ch2->iir[2].B0=1;
ch2->iir[2].B1=0;
ch2->iir[2].B2=0;
ch2->iir[2].A1=0;
ch2->iir[2].A2=0;
EnableAxis(0);
EnableAxis(1);
EnableAxis(2);
DefineCoordSystem(0,-1,1,-1);
ok i got the spindle performing well
the only issue is i have to double push the CW/CCW buttons to work
which ever button i push first is the way it will rotate. (first push does nothing but pick which way to rotate)
the second time i push one of the buttons it will turn on spindle. ( this can be either CW or CCW as the first button push locks in which direction to rotate)
my CW
my CCW
my jog
my off
my CW
int *css_mode = &persist.UserData[PC_COMM_CSS_MODE]; // Mode 1=Normal RPM mode. 2=CSS
float speed = *(float *)&persist.UserData[SPEEDVAR]; // value stored is actually a float
int LastState = persist.UserData[STATEVAR]; // get last state
if (CS0_axis_a == -1 && !ch2->Enable) // is A axis not defined in the Coordinate System and not enabled?
EnableAxis(2); // yes, enable the axis
if (LastState==-1)
// if spindle was CCW now we want CW
// spin down
ClearBit(SPINDLECW_BIT);
ClearBit(SPINDLECCW_BIT);
Jog(SPINDLEAXIS,0);
while (!CheckDone(SPINDLEAXIS)) ;
// turn spindle on CW and ramp to new speed
SetBit(SPINDLECW_BIT);
LastState = 1; // Add string
if (*css_mode != 2)
if (USE_POS_NEG_VOLTAGE)
persist.UserData[STATEVAR] = 1; // remember we are CW
if (LastState==1)
// if spindle was CW now we want CCW
// spin down
Jog(SPINDLEAXIS,0);
// turn spindle on CCW and ramp to new speed
SetBit(SPINDLECCW_BIT);
LastState = -1;
if (*css_mode != 2)
persist.UserData[STATEVAR] = -1; // remember we are CCW
my jog
float speed = *(float *)&persist.UserData[KMVAR]; // value stored is actually a float
persist.UserData[SPEEDVAR] = persist.UserData[KMVAR]; // Always save the last desired speed
if (LastState==0 || *css_mode == 2)
// if spindle is off (or CSS mode) and User Changes the speed
// just save the desired speed
my off
// spin down
Jog(SPINDLEAXIS, 0);
printf("Jogging Spindle Stop\n");
persist.UserData[STATEVAR] = 0; // remember we are Off
while (!CheckDone(SPINDLEAXIS));
if (CS0_axis_a == -1) // is A axis not defined in the Coordinate System?
DisableAxis(2); // yes, disable the axis, otherwise leave it enabled
sigh....
so i just tried some other C code examples that did the same double push thing
i re-load my own ones i posted above and now it works perfect
this is what blows my mind.
i am about to get a go pro camera and film what happens
ok, i got another used AMC drive ( 250$ ebay ) and the Z axis works as it should again!
everything works.
stoked
everything works.
stoked
i take pride in completion.
