Spindle Interface
jackgiz
Spindle Interface
Post by jackgiz » Fri Mar 31, 2023 10:26 pm
I have my spindle mostly working. I can turn it on and off, change rotation and change speed. However, having some problems with getting requested speed and actual speed to agree. From the console I did Jog6=100000 and set V out from my C6 board to 10 volts which gave me 24,000 RPM on the inverter display. I did a Jog6=50000 and measured the voltage again and it was 5volts like I would expect. However, instead of 12,000 RPM I had 14,500. I took 100,000/24,000 RPM = 4.166 and used that number in the spindle programs "Factor" variable. I then did an M3 S10000 and got something like 14,000 RPM. As I increased S the difference between the requested RPM and actual got closer. At 24,000 it was right on. The different line slopes between requested RPM and Actual RPM I believe is an inverter issue but I don't see a setting to help correct that problem in the invert documentation. What is the best way to over come this issue in Kmotion? Should I come up with a formula that I can use in the Factor variable or is there a better way?
Jack
Re: Spindle Interface
Post by TomKerekes » Sun Apr 02, 2023 8:03 pm
Hi Jack,
If the measured voltages respond linearly then KFLOP and the C6 are working correctly. I agree the issue seems to be with the Inverter.
Is there an encoder output from the Spindle or Inverter? If so you could run closed loop for exact speed control.
Otherwise I think you would need to include a correction formula.
jackgiz
Post by jackgiz » Tue May 02, 2023 1:01 am
I found that moving the inverter and C6 as far from the control panel and wiring as possible and running a shielded CAT 5 cable between the Kflop and C6 seems to have fixed the non linear issues and any other strange occurrences.
It does appear that there is an output that could be used for feedback to the Kflop with a couple of different operating modes. See attachment. This is all the documentation I can find at the moment. Is there a sample C program that I might be able to use for this feedback loop?
The only remaining minor issue is that when the spindle is running, if I adjust the spindle speed slider the spindle turns off. If I then click the ON CW button the spindle restarts and goes to the new speed set by the slider. I'm using the Spindle C programs provided with Kmotion, i.e., SpindleMillJogDir.c, SpindleOnCCWJogDir.c, SpindleOnCWJogDir.c and SpindleOffJogDir.c. Why is the Spindle turning off?
Jack
jackgiz
Post by jackgiz » Tue May 02, 2023 1:03 am
forgot to attach this file to the previous reply.
Post by TomKerekes » Tue May 02, 2023 1:33 am
Hi Jack,
I can't think of a reason the Spindle would stop.
What is printed on the KMotion.exe Console when you move the slider and the Spindle stops?
Usually you are required to modify those program's defines for your system. Please post the exact 4 programs you are using.
Also post KMotionCNC's Tool Setup's configuration for those files.
jackgiz
Post by jackgiz » Wed May 03, 2023 4:29 pm
Today's issue is slightly different. If I start my spindle out at 12,000 RPM (50832 counts/sec) and click on the slider the spindle doesn't stop but immediately slows to 6000 RPM even though the console shows an increase in counts/sec.
Jogging Spindle 50832.000000 counts/sec //Now click on slider. Slider display still says 1.00 but counts increase
Jogging Spindle 52008.000000 counts/sec //Clicking on Off stops the spindle.
Jogging Spindle Stop
version
KFLOP 4.35h Build 14:31:18 Sep 19 2022
KFLOP 4.35h
Ready
See Attached.
See Attached.
Am I using KMVAR correctly?
Jack
SpindleOnCWJogDir.c
(1.07 KiB) Downloaded 242 times
(1.05 KiB) Downloaded 238 times
SpindleOffJogDir.c
(645 Bytes) Downloaded 236 times
SpindleMillJogDir.c
(991 Bytes) Downloaded 243 times
Post by TomKerekes » Wed May 03, 2023 6:22 pm
Hi Jack,
I think I see the problem. In SpindeMillJogDir.c this:
	Jog(SPINDLEAXIS, LastState * speed);
	printf("Jogging Spindle %f counts/sec\n", speed * FACTOR);
Commands the speed without using the FACTOR but prints using it. Try changing to:
	Jog(SPINDLEAXIS, speed * FACTOR);
jackgiz
Post by jackgiz » Fri May 05, 2023 2:53 am
Thanks, that was it. I must have changed that line when I was getting my spindle working and forgot to change it back.
Next question, if I change the slider while running a program that new slider multiplier does not reset when I start the next program. How can I get the slider to reset to 1 when I start the next program? Same question for resetting the forward speed slider.
Jack
Post by TomKerekes » Sat May 06, 2023 8:58 pm
Hi Jack,
Its not clear if an Operator would always want that.
But calling this from a forever loop should reset them whenever execution begins.
// Reset all sliders whenever execution starts
void ResetSliders(void)
	static int PrevJobActive=-1;
	int NewJobActive;
	NewJobActive = JOB_ACTIVE;  //sample
	if (NewJobActive != PrevJobActive)  // changed?
		PrevJobActive = NewJobActive; //save
		if (NewJobActive) // started?
			DoPCFloat(PC_COMM_SET_FRO,1);  // Reset Sliders
			DoPCFloat(PC_COMM_SET_RRO,1);
			DoPCFloat(PC_COMM_SET_SSO,1);
jackgiz
Post by jackgiz » Wed May 10, 2023 5:28 pm
That worked. Took a little bit of thinking for a copy and paste programmer like me but I finally figured it out.
Jack
