Halt pause movement, but continue executing tool changer routine.
gui_marchioro
Post by gui_marchioro » Fri Nov 04, 2022 2:59 am
I am facing some problems when trying to halt during an M6 command execution. The halt only seems to pause the axes movements, but keep executing the tool changer routine (video attached).
Is that the expected behavior from the halt command?
Thanks in advance for the reply.
Sincerely,
Guilherme
Re: Halt pause movement, but continue executing tool changer routine.
Post by TomKerekes » Fri Nov 04, 2022 4:53 pm
Hi Guilherme,
You would have to add checks throughout the Tool Change program to detect Halt and stop/exit. You could add the checks at points where it would be appropriate to stop. Most likely every place that loops waiting for something to finish. You should be able to check JOB_ACTIVE to determine if the Job was Halted. ie
		if (!JOB_ACTIVE) return;  // if Job was terminated exit
Depending on the situation you might want to do something besides exiting. Such as Stopping a motion with a Jog to zero speed.
gui_marchioro
Post by gui_marchioro » Mon Nov 07, 2022 1:17 pm
I have tested and it worked. Thank you for the insight!
Sincerely,
Guilherme
