I have send all the files in your email.
Regards.
Exec/Wait from inside a c program
Re: Exec/Wait from inside a c program
Your M3 Action is just setting a bit so of course it doesn't wait. Change it to a C Program with the wait in it.
I make i M3 handling c program "DoM3.c" which is called by M3 in KmotionCNC with an action Exec/wait.
This program "DoM3.c" sets a virtual bit (1031) and then "presses" the button 116, in order to execute the Torch_zero_find.c, which also happens, ok.
The "DoM3.c" should then wait, via until this bit is setted by Torch_zero_find.c when finishes, which is not happens. The execution of Torch_zero_find.c starts but the DoM3.c finishes before the Torch_zero_find.c does.
Why is this happen?
#define PLASMA 1068 // Operation Plasma
#define T_SELECT1 1069
#define T_SELECT2 1070
#define CUT_VLV1 154 //
#define M3 48
//- P L A S M A O P E R A T I O N -
if(ReadBit(PLASMA) && !ReadBit(T_SELECT1) && !ReadBit(T_SELECT2) ){
if(!ReadBit(1030)){
SetBit(1031);
ScreenScript("WinMsg:Keyboard;;KeyPress;122");
SetBit(1030);
while(ReadBit(1031)); // Bit 1031 is reset by Torch_zero_find, when it finishes
//- O X Y F U E L O P E R A T I O N -
if(!ReadBit(PLASMA) && ReadBit(T_SELECT1) || ReadBit(T_SELECT2)){
SetBit(M3);
while(ReadBit(1031));Why is this happen?
That looks correct to me except you said Key 116 but it does 122.
Where are you setting Bit 1031? Are you possibly setting it somewhere else?
You might add printf statements to troubleshoot what is actually happening.
Please post all your programs (do not email them to me).
This is the Torch_zero_find.c which is called from user button 9 key 122, not as i wrote by mistake 116.
The DoM3 is called by M3 via action Exec/wait from KmotionCNC.
#include "PC-DSP.h"
int DoPC(int cmd);
int DoPCFloat(int cmd, float f);
int DoPCInt(int cmd, int i);
int SetVars(int poff, int varoff, int n);
int GetVars(int varoff, int n, int poff);
void MoveUp(double distance);
void MoveDown(double distance);
void ProbeDown();
// Globals
double *pD = (double *)persist.UserData,t1,t2,PreheatTime,PierceDelay;
float xRes, yRes, zRes;
int TMR1,TMR2;
#define PROBEBIT 1032 //143
#define PROBESPEED 500.0f
#define XAXIS 0
#define YAXIS 1
#define ZAXIS 3
#define UPSPEED -500.0f
#define DOWNSPEED (PROBESPEED * 0.5f)
#define PIERCE_HEIGHT 5.0f
#define PIERCE_DELAY 0.1f
#define CUTTING_HEIGHT 4.0f
#define IGNITION_HEIGHT 0.1f
#define SWITCH_OFFSET 4.0f
#define M3 48
#define RESUME 55
#define PLASMA_ON 152
//#define ARC_IS_ON 139
#define ARC_IS_ON 1025
#define GAS_VLV 153 //
#define PRE_HI_VLV 153 //
#define PRE_LOW_VLV 153 //
#define EXAUST_VLV 155
#define PLASMA 1068 // The first torch position "Operation Plasma"
#define T_SELECT1 1069 // "Oxy Fuel operation"
#define T_SELECT2 1070 // "Oxy Fuel operation"
double ProbeBit,ProbeSpeed,Xaxis,Yaxis,Zaxis,UpSpeed,DownSpeed,PierceHeight,PlateThickness,CuttingHeight,IgnitionHeight;
char s[256];
printf("\n\nStarting M3\n");
// Download Variables from GCode #110 to persists
GetVars(110, 10, 10);
ProbeSpeed = pD[10]; //#110
UpSpeed = pD[11]; //#111
DownSpeed = pD[12]; //#112
PierceHeight = pD[13]; //#113
PierceDelay = pD[14]; //#114
CuttingHeight = pD[15]; //#115
IgnitionHeight = pD[16]; //#116
DoPCInt(PC_COMM_GETAXISRES, 50);
//xRes = (*(float *)&persist.UserData[50])/25.4;
//yRes = (*(float *)&persist.UserData[51])/25.4;
zRes = (*(float *)&persist.UserData[52])/25.4;
//printf("Axis Resolutions Found:\ntz: %f\n",zRes);
//printf("Probe Speed: %f\nUp Speed: %f\nDown Speed: %f\nPierce Height: %f\n", ProbeSpeed,UpSpeed,DownSpeed,PierceHeight);
//printf("Pierce Delay: %f\nCutting Height: %f\nIgnition Height: %f\n", PierceDelay,CuttingHeight,IgnitionHeight);
//= P L A S M A O P E R A T I O N =
printf("PLASMA\n");
// Find Z Height
ProbeDown();
ProbeUp();
MoveUp(SWITCH_OFFSET);
DoPCFloat(PC_COMM_SET_Z, 0);
DoPCFloat(PC_COMM_SET_A, 0);
MoveUp(IgnitionHeight);
printf("Turn on plasma\n");
SetBit(PLASMA_ON);
printf("Waiting for arc on\n");
while(!ReadBit(ARC_IS_ON));
MoveUp(PierceHeight); // Move relative Up for piercing
Delay_sec(PierceDelay);
MoveDown(PierceHeight); // Move down again relative where you started "Ignition Height"
MoveDown(IgnitionHeight-CuttingHeight); // Move down again relative where you started "Ignition Height"
printf("Ok to move\n");
SetBit(1024);
DefineCoordSystem(0,1,4,-1);
ClearBit(1031);
//= O X Y F U E L O P E R A T I O N =
if((ReadBit(T_SELECT1) || ReadBit(T_SELECT2)) && !ReadBit(PLASMA) ){
//SetBit(M3); // Start the internal M3
//printf("Moving Up by %f\n", distance);
MoveRel(ZAXIS, distance * zRes);
while (!CheckDone(ZAXIS));
//printf("Moving Down by %f\n", distance);
MoveRel(ZAXIS, -1 * distance * zRes);
void ProbeDown()
printf("Jogging Down at speed:%f\n", DOWNSPEED);
Jog(ZAXIS, DOWNSPEED);
printf("Waiting for probe to read high\n");
while (ReadBit(PROBEBIT));
printf("Stopping\n");
Jog(ZAXIS, 0);
printf("Waiting for Z motion to stop\n");
void ProbeUp()
printf("Jogging Up at speed:%f\n", DOWNSPEED);
Jog(ZAXIS, -1*DOWNSPEED);
printf("Waiting for probe to read low\n");
while (!ReadBit(PROBEBIT));
Jog(ZAXIS, 0);
int SetVars(int varoff, int n, int poff)
persist.UserData[PC_COMM_PERSIST+2] = n; // number of elements
persist.UserData[PC_COMM_PERSIST+3] = poff; // persist offset (doubles)
return DoPCInt(PC_COMM_SET_VARS,varoff); // Var index and Cmd
return DoPCInt(PC_COMM_GET_VARS,varoff); // Var index and Cmd
// put the MDI string (Manual Data Input - GCode) in the
// gather buffer and tell the App where it is
int MDI(char *s)
char *p=(char *)gather_buffer+GATH_OFF*sizeof(int);
int i;
do // copy to gather buffer w offset 0
*p++ = *s++;
}while (s[-1]);
// issue the command an wait till it is complete
// (or an error - such as busy)
return DoPCInt(PC_COMM_MDI,GATH_OFF);
// Put a Float as a parameter and pass the command to the App
int result;
persist.UserData[PC_COMM_PERSIST+1] = *(int*)&f;
return DoPC(cmd);
// Put an integer as a parameter and pass the command to the App
int result;
persist.UserData[PC_COMM_PERSIST+1] = i;
return DoPC(cmd);
// Pass a command to the PC and wait for it to handshake
// that it was received by either clearing the command
// or changing it to a negative error code
int DoPC(int cmd)
int result;
persist.UserData[PC_COMM_PERSIST]=cmd;
do
}while (result=persist.UserData[PC_COMM_PERSIST]>0);
// printf("Result = %d\n",result);
return result;
It seems to work properly for me. But I had to delete much of your code as I don't have your hardware.
There is one problem with the Keypress. With a screen script its Action has priority and overrides the button action so the C Program isn't called.
Like I suggested before use:
which issues the Action directly without the need for a button. When I posted that previously somehow spaces were introduced which causes it not to work.Maybe that is why you decided to do it differently than what I suggested.
Please post your Initialization file so we can check for conflicts.
if (ScreenScript("Action:5;3;-1;0;0;0;Torch_zero_find.c"))
