Tool Diameter compensation giving error of gauge
AmitKumar171
Post by AmitKumar171 » Mon Sep 20, 2021 12:32 pm
Hi tom,
I am using Kflop+konnect for my cnc machine. I am facing one problem in G40, G41, G42 (Tool diameter compensation).
It is giving error of tool gauge while simulation as well as actual run of g code on machine.
I am attaching G code and screenshot of error i am facing.
gcode.nc.txt
(245 Bytes) Downloaded 180 times
Please suggest any probable solution of below problem. If I am doing something wrong ?
Waiting for your kind reply.
Thank You
AMIT KUMAR
Re: Tool Diameter compensation giving error of gauge
Post by TomKerekes » Mon Sep 20, 2021 4:39 pm
Hi Amit,
G42 moves the tool on the right side of the specified path. It is not possible to go through inside concave corners without gouging. What are you trying to do? Here is a plot of your GCode:
There must also be an Entry Move to apply radius compensation immediately after turning it on. See also.
AmitKumar171
Post by AmitKumar171 » Tue Sep 21, 2021 6:06 am
Hi tom,
Thank you for your reply.
Does this radius compensation works in 3+2 axis mode with RTCP on (G43.4).
If yes then is there anything to enable in settings??
If not then how can we make it work ?
Thank You
AMIT KUMAR
Post by TomKerekes » Tue Sep 21, 2021 2:57 pm
Hi Amit,
Radius Compensation should work in the XY plane as in any XYZ Mill.
