JP5 - max output frequency
cemoa9
Post by cemoa9 » Sat Sep 18, 2021 10:49 am
Trying to mill the first part with kflop, I found a new issue, I have a spindle controller driven in step/dir, 2500pulses / rotation, but after 2700rpm the spindle would just stop and driver would say no pulse received. I checked with an osciloscope, signal is clear until 2700RPM, but would be just noise from 2800rpm.
Remembered then the pulse length set-up, but if I set it too low (to reach the 8000rpm of the spindle) then the X-Y drives will not work, can it be set-up by channel?
Cordially
Francois
Re: JP5 - max output frequency
Post by TomKerekes » Sat Sep 18, 2021 3:23 pm
Hi Francois,
No there is one setting for all Step Generators. Do any of the Drives accept quadrature input mode? Depending on the mode and interface you are using adding a 5V driver to the signal may help.
cemoa9
Post by cemoa9 » Sat Sep 18, 2021 3:41 pm
The spindle drive accepts AB inputs, but I do not really understand what you mean with 5V driver. :oops:
Cordially
Francois
Post by TomKerekes » Sat Sep 18, 2021 3:45 pm
Hi Francois,
AB quadrature should work better. There is no pulse width associated with this. Each edge cause a step and the frequency is half what pulses would be. Set the pulse width longer for your other drives.
cemoa9
Post by cemoa9 » Sun Sep 19, 2021 2:54 pm
Works perfectly.
Thx
cemoa9
Post by cemoa9 » Tue Oct 19, 2021 9:19 am
Playing with the programs to shorten the tool change I noticed a strange behavior, sequence performed is :
JOG spindle 1000
JOG spindle 0
Reset Spindle ON Bit
Perform SPINDLE HOMING (Done by spindle controller)
Set Spindle ON Bit
and when setting the position Bit the spindle would go fast without command, and no destination change in Kmotion.
I checked the signal and made a video :
https://drive.google.com/file/d/1bB2ikE ... sp=sharing
We see an ok signal for the JOG 1000, the nothing for the JOG 0, but then comes a smaller signal for a short period.
Any idea of what it is? (Noise from the Spindle drive?)
Cordially
Francois
Post by TomKerekes » Tue Oct 19, 2021 4:24 pm
Hi Francois,
I don't fully understand what you are doing or what signals you are referring to, but if you disable the Servo Drive, move the axis to cause a large difference between the commanded Destination and measured Position, then re-enable the Servo Drive, the huge error will cause a violent motion to attempt to drive the Position back to the commanded Destination. The KFLOP Axis should be disabled while the Servo Drive is disabled, then re-enabled setting the Destination to the new Position. ie for axis 3:
EnableAxisDest(3, ch3->Position);
cemoa9
Post by cemoa9 » Wed Oct 20, 2021 9:17 am
You guessed well, works fine with your solution.
Thank you.
Francois
