destroyed shop and new builds.
turbothis
Post by turbothis » Fri Aug 20, 2021 6:01 pm
last September a wild fire burned mine and like 3000 other homes and buildings to the ground.
all my hard work building the old machines
anyways new machine to build and new questions!!!
i got my sharnoa started now
i got the panel wired up some and run into my first issues
1 the Y axis encoder slowly runs off forever. right when i wired it up it was fine. not sure what changed?
	ch0->InputMode=ENCODER_MODE;
	ch0->Vel=40000;
	ch0->Accel=400000;
	ch0->Jerk=4e+06;
	ch0->P=0;
	ch0->I=0.01;
	ch0->D=0;
	ch0->FFAccel=0;
	ch0->FFVel=0;
	ch0->MaxI=200;
	ch0->MaxErr=1e+06;
	ch0->MaxOutput=200;
	ch0->DeadBandGain=1;
	ch0->DeadBandRange=0;
	ch0->InputChan0=0;
	ch0->InputChan1=0;
	ch0->OutputChan0=0;
	ch0->OutputChan1=0;
	ch0->MasterAxis=-1;
	ch0->LimitSwitchOptions=0x12f;
	ch0->LimitSwitchNegBit=136;
	ch0->LimitSwitchPosBit=137;
	ch0->SoftLimitPos=1e+09;
	ch0->SoftLimitNeg=-1e+09;
	ch0->InputGain0=1;
	ch0->InputGain1=1;
	ch0->InputOffset0=0;
	ch0->InputOffset1=0;
	ch0->OutputGain=1;
	ch0->OutputOffset=0;
	ch0->SlaveGain=1;
	ch0->BacklashAmount=0;
	ch0->BacklashRate=0;
	ch0->invDistPerCycle=1;
	ch0->Lead=0;
	ch0->StepperAmplitude=20;
	ch0->iir[0].B0=1;
	ch0->iir[0].B1=0;
	ch0->iir[0].B2=0;
	ch0->iir[0].A1=0;
	ch0->iir[0].A2=0;
	ch0->iir[1].B0=1;
	ch0->iir[1].B1=0;
	ch0->iir[1].B2=0;
	ch0->iir[1].A1=0;
	ch0->iir[1].A2=0;
	ch0->iir[2].B0=0.000768788;
	ch0->iir[2].B1=0.00153758;
	ch0->iir[2].B2=0.000768788;
	ch0->iir[2].A1=1.92076;
	ch0->iir[2].A2=-0.923833;
	EnableAxis(0);
	ch1->InputMode=ENCODER_MODE;
	ch1->Vel=40000;
	ch1->Accel=400000;
	ch1->Jerk=4e+06;
	ch1->P=0;
	ch1->I=0.01;
	ch1->D=0;
	ch1->FFAccel=0;
	ch1->FFVel=0;
	ch1->MaxI=200;
	ch1->MaxErr=1e+06;
	ch1->MaxOutput=200;
	ch1->DeadBandGain=1;
	ch1->DeadBandRange=0;
	ch1->InputChan0=1;
	ch1->InputChan1=0;
	ch1->OutputChan0=1;
	ch1->OutputChan1=0;
	ch1->MasterAxis=-1;
	ch1->LimitSwitchOptions=0x12f;
	ch1->LimitSwitchNegBit=138;
	ch1->LimitSwitchPosBit=139;
	ch1->SoftLimitPos=1e+09;
	ch1->SoftLimitNeg=-1e+09;
	ch1->InputGain0=1;
	ch1->InputGain1=1;
	ch1->InputOffset0=0;
	ch1->InputOffset1=0;
	ch1->OutputGain=1;
	ch1->OutputOffset=0;
	ch1->SlaveGain=1;
	ch1->BacklashAmount=0;
	ch1->BacklashRate=0;
	ch1->invDistPerCycle=1;
	ch1->Lead=0;
	ch1->StepperAmplitude=20;
	ch1->iir[0].B0=1;
	ch1->iir[0].B1=0;
	ch1->iir[0].B2=0;
	ch1->iir[0].A1=0;
	ch1->iir[0].A2=0;
	ch1->iir[1].B0=1;
	ch1->iir[1].B1=0;
	ch1->iir[1].B2=0;
	ch1->iir[1].A1=0;
	ch1->iir[1].A2=0;
	ch1->iir[2].B0=0.000769;
	ch1->iir[2].B1=0.001538;
	ch1->iir[2].B2=0.000769;
	ch1->iir[2].A1=1.92081;
	ch1->iir[2].A2=-0.923885;
	EnableAxis(1);
	ch2->InputMode=ENCODER_MODE;
	ch2->Vel=40000;
	ch2->Accel=400000;
	ch2->Jerk=4e+06;
	ch2->P=0;
	ch2->I=0.01;
	ch2->D=0;
	ch2->FFAccel=0;
	ch2->FFVel=0;
	ch2->MaxI=200;
	ch2->MaxErr=1e+06;
	ch2->MaxOutput=200;
	ch2->DeadBandGain=1;
	ch2->DeadBandRange=0;
	ch2->InputChan0=2;
	ch2->InputChan1=0;
	ch2->OutputChan0=2;
	ch2->OutputChan1=0;
	ch2->MasterAxis=-1;
	ch2->LimitSwitchOptions=0x12f;
	ch2->LimitSwitchNegBit=140;
	ch2->LimitSwitchPosBit=141;
	ch2->SoftLimitPos=1e+09;
	ch2->SoftLimitNeg=-1e+09;
	ch2->InputGain0=1;
	ch2->InputGain1=1;
	ch2->InputOffset0=0;
	ch2->InputOffset1=0;
	ch2->OutputGain=1;
	ch2->OutputOffset=0;
	ch2->SlaveGain=1;
	ch2->BacklashAmount=0;
	ch2->BacklashRate=0;
	ch2->invDistPerCycle=1;
	ch2->Lead=0;
	ch2->StepperAmplitude=20;
	ch2->iir[0].B0=1;
	ch2->iir[0].B1=0;
	ch2->iir[0].B2=0;
	ch2->iir[0].A1=0;
	ch2->iir[0].A2=0;
	ch2->iir[1].B0=1;
	ch2->iir[1].B1=0;
	ch2->iir[1].B2=0;
	ch2->iir[1].A1=0;
	ch2->iir[1].A2=0;
	ch2->iir[2].B0=0.000769;
	ch2->iir[2].B1=0.001538;
	ch2->iir[2].B2=0.000769;
	ch2->iir[2].A1=1.92081;
	ch2->iir[2].A2=-0.923885;
	EnableAxis(2);
	DefineCoordSystem(0,1,2,-1);
2 spindle settings. i got the simple version started for the m3 m4 and m5. S command looks good.
the analog 10v (DAC7) does not reflect the volts that the analog status is showing. 10V on status and .25v on multimeter DAC7?
VFD reads true on the .25v.....
3 spindle rotation. FET 0 and 1 toggle fine for the CW and CCW on the digital I/O screen. the VFD does not accept the commands though. i set the
parameters on the VFD for 0-10 external command. i multimetered the FET pins and they dont ground the 5V pins below it when
toggled.
turbothis
Re: destroyed shop and new builds
Post by turbothis » Fri Aug 20, 2021 6:28 pm
i pulled the 5V to the Y axis encoder and it is still running off slowly
noise issue?
Post by TomKerekes » Fri Aug 20, 2021 7:09 pm
Hi turbothis,
So sorry to hear that.
You might read this.
Where are you measuring? You might issue DAC commands manually as described here.
toggled.
Where are you measuring? How is it wired? Do you have a GND connection?
turbothis
Re: destroyed shop and new builds.
Post by turbothis » Fri Aug 20, 2021 7:25 pm
spindle. i command DAC7=2000 and read 9.766 volts on the I/O page but get .25 volts on the DAC7 pin
VFD reads 001.15
different DAC commands do not change the actual output
turbothis
Post by turbothis » Fri Aug 20, 2021 7:40 pm
i cycled power to kflop and now encoder run away is gone. lol = fixed!
turbothis
Post by turbothis » Fri Aug 20, 2021 7:44 pm
lol! ok now spindle work as it should!
Post by TomKerekes » Fri Aug 20, 2021 8:17 pm
Hi turbothis,
It appears the Enable LED on Kanalog is not on. Is it? Is the ribbon cable between KFLOP and Kanalog seated properly?
turbothis
Post by turbothis » Fri Aug 20, 2021 8:27 pm
interesting. it is on now.
not sure if it was before i cycled the power.....
