Axis jerk, servo tuning and capturing data
GabrielR922
Re: Axis jerk, servo tuning and capturing data
Post by GabrielR922 » Wed Aug 18, 2021 11:04 pm
Hi Tom.
The machine is capable of 45m/min. If 17hz is 4m/min it can do 170hz at 40m/min?
Also, bought a pendant that has a 24v encoder. is there a way to wire it to kanalog ?
If not, i may test with 5v even if it is 24v?
Thanks.
Post by TomKerekes » Thu Aug 19, 2021 3:21 am
I don’t understand the question.
you would need to post the specifications that describe what type of output it has. Open collector?
GabrielR922
Post by GabrielR922 » Fri Aug 20, 2021 12:51 pm
Hi Tom.
Here is the scheme for the MPG pendant.
Post by TomKerekes » Fri Aug 20, 2021 6:47 pm
Hi Gabriel,
That doesn't really help and seems to indicate a 5V encoder.
GabrielR922
Post by GabrielR922 » Fri Aug 20, 2021 7:10 pm
Hi Tom.
This is what i have from the chinese manufator. The encoder is 24v. The paper shows 5v but it's 24v.
Is there a way to test if kanalog is able to read the return of the encoder?
Post by TomKerekes » Fri Aug 20, 2021 7:15 pm
Hi Gabriel,
Never connect a 24V signal to Kanalog encoder inputs.
Test with an oscilloscope or voltmeter that the outputs are 5V or less before connecting.
