Move axis to dest and at speed
GabrielR922
Post by GabrielR922 » Sat May 29, 2021 1:57 pm
Hi Tom
I'm trying to move my axis to a home position with a C code.
The home position will be always relative to machine G53 0.
So I need a way to script in C a G1 G53 X100 Y100 F10000.
Tried MoveXYZ but it won't work. Also it would be nice to use Machine coordinate, not units. (like Move command).
Thanks.
Re: Move axis to dest and at speed
Post by TomKerekes » Sat May 29, 2021 3:44 pm
Hi Gabriel,
The simplest method is to make 2 MoveAtVel() calls. The motion of X and Y will be simultaneous but independent and not necessarily on a straight line. A trick to make it on a straight line is to scale the Velocities, Accelerations, and Jerks proportional to the distance each axis is to move relative to the combined vector distance.
Or you might perform a G53 MDI command to KMotionCNC.
Otherwise to do a coordinated motion see the CoordMotion C examples.
