I run your dynomotion with snapamp and a konnex module for operate a pick and place machine. All work perfecly for a long time, but some time, the axys start to move randomly or just certain axe stop to run and the other still running.
A power reset on the kflop doen't solve this issue. As soon as power on, the axys move randomly and smash to the hard limit.
For a restart, we need to close the kmotion software, power reset the kflop and reopen the software.
In operation, in the beginning, we run PAL-XPSAFv1-InitAxes.c and after open PAL-Master-with XPSAF-v1.c in the thread 1. We use cnc kmotion to do launch the c threads.
We put some time in programmation to solve this issues and it still remain. We try many stategy on the reiniating of the axys.
When we are there and test the machine for hundred of cycles, we have no issue. Suddently, the machine start to behave random.
When the machine is in bug condition, for one axys, the others motions on other axys still running and move a random ammount of ask motion then the sequence pass to the next step like the checkdone was reach. But in reality, the axys didn't complete the motion.
Axys move randomly
4minnovations
Axys move randomly
- screen.zip
- (53.34 KiB) Downloaded 731 times
- program C.zip
- (49.57 KiB) Downloaded 711 times
4minnovations
Re: Axys move randomly
I would like to know wich c program the kflop use, because I think of sometime the kflop use the wrong c program.
With a button in the kmotionCNC, I lauch my principal c program in the thread #1 from the PC. I think that sometime after a reboot, the kflop use the principal c program in the flash memory. This is possible?
I don't see anything obvious. The C Code is very complex and I don't understand how it is supposed to work. Maybe you could explain how KFLOP is commanded to do things.
I can't load the Screen as there are many missing files. Mainly from: \documents4M_PAL\image
To:
So a disable will still be considered Not Done. Or check for -1 and display an error.
Probably not an issue but: void estopEnclenche(int choixErreurAfficher);
is used before being defined.
"long" are used instead of "int". This shouldn't be an issue but don't recommend it.
I don't completely understand what you are saying. But CheckDone() returns -1 if the axis is disabled which is also considered as True as a condition. So you might change Code like this:When the machine is in bug condition, for one axys, the others motions on other axys still running and move a random ammount of ask motion then the sequence pass to the next step like the checkdone was reach. But in reality, the axys didn't complete the motion.
if((CheckDone(0))&&(CheckDone(1))&&(CheckDone(2)))Code: Select all
if((CheckDone(0)==1)&&(CheckDone(1)==1)&&(CheckDone(2)==1))Probably not an issue but: void estopEnclenche(int choixErreurAfficher);
KFLOP defaults to all axes disabled on power up. So your program or screen must be enabling things for anything to move. Or you have Flashed a configuration or program.A power reset on the kflop doen't solve this issue. As soon as power on, the axys move randomly and smash to the hard limit.
KFLOP uses whatever program has been loaded and commanded to execute. We don't recommend Flashing any configuration or Programs to KFLOP as Users often forget what changes they made to KFLOP. I suggest you remove any Programs and reset to KFLOP to the default configuration by re-Flashing "New Version".I would like to know wich c program the kflop use, because I think of sometime the kflop use the wrong c program.
4minnovations
Thanks tom,
I know the program is really complicated, but i will make some changes as suggested in your answer.
In addition, I will make sure to return to the default configuration by re-flashing "New version".
