I am having trouble going between Coordinatied Motion and Single axis motion. It seems I am not setting Accel and Decel with results.
I have listed the code I used in DYN_AxisGroup.cs to init(...).
I have changed the following with no effect:
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxAccelX = 3000;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxAccelY = 600;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxAccelZ = 600;
and
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxVelX = axes[0].MaxVel;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxVelY = axes[1].MaxVel;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxVelZ = axes[2].MaxVel;
Thank you,
David Taylor
public void Init(List<AxisNodeContainer> axes, int devicenumber, string name,
double vvel, double vacc, double vdec, double v_Jerk)
axisNum = 0;
foreach (AxisNodeContainer axis in _Axes)
if (axis.Node.Inverted)
invert = -1D;
invert = 1D;
_CPU[axisNum] = axis.Node.CountsPerUnit * invert;
_AxisNums[axisNum] = axis.Node.AxisData.NodeId;
_MaxAccel[axisNum] = axis.Node.MaxAccel;
_MaxDecel[axisNum] = axis.Node.MaxDecel;
_MaxJerk[axisNum] = axis.Node.JerkPercentage;
axisNum++;
_AccelCounts = AxisUtil.AccelToCounts(_MaxAccel, _CPU);
_DecelCounts = AxisUtil.AccelToCounts(_MaxDecel, _CPU);
_Jerk = _MaxJerk;
_VectorVelocity = vvel;
_VectorAccel = vacc;
_VectorDecel = vdec;
_VectorJerk = v_Jerk;
var axislist = from a in _Axes select a.GetDevice() as KM_Axis;
_AxisGroupObject = new KM_AxisGroup(DYN_Controller.Instance.Controller, axislist.ToArray());
DYN_Controller.Instance.Controller.CoordMotion.Abort();
DYN_Controller.Instance.Controller.CoordMotion.ClearAbort();
DYN_Controller.Instance.Controller.WriteLine(String.Format("DefineCS = {0} {1} {2} {3} {4} {5}", 0, 1, 2, -1, -1, -1));
DYN_Controller.Instance.Controller.WriteLine(String.Format("EnableAxis{0}", 0));
DYN_Controller.Instance.Controller.WriteLine(String.Format("EnableAxis{0}", 1));
DYN_Controller.Instance.Controller.WriteLine(String.Format("EnableAxis{0}", 2));
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.BreakAngle = 30;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.RadiusA = 5;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.RadiusB = 5;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.RadiusC = 5;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxAccelA = 3000;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxAccelB = 3000;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxAccelC = 3000;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxVelA = 100;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxVelB = 100;
DYN_Controller.Instance.Controller.CoordMotion.MotionParams.MaxVelC = 100;
Coordinated Motion and Single axis motion
david.b.taylor
Re: Coordinated Motion and Single axis motion
Hi David,
I don't see how you are commanding Single Axis Motions or from where, but Independent Axis Motions use the Velocity, Acceleration, and Jerk settings within KFLOP. I prefer to set those with an initialization C Program. But they can also be set from .NET with KM_Axis.Velocity, KM_Axis.Acceleration, and KM_Axis.KM_Axis_TuningParams.Jerk. You might also see this.
david.b.taylor
The behavior i am getting is no acel or decel when I am in the coordinated moves. When I am single axis motion it is fine.
What sets the acel and decel for each axis when in coordination moves?
David.
David.
Hi David,
Ah. I think you are setting the right parameters (MotionParams), but the wrong units. KFLOP units are in motor counts and seconds. The MotionParams are in inches and seconds. See here. So 3000 inches/sec^2 would be crazy high acceleration ~8Gs. Normally the value would be something like 30 in/s^2 or 0.08G.
