hI TOM,
I am using kflop+kanalog+konnect.
I want to select single block option in kmotioncnc using a physical button.
How to do programming for that, any suggestions.??
waiting for your kind reply.
HOW TO SELECT SINGLE BLOCK OPTION IN KMOTIONCNC
Thank You
AMIT KUMAR
AMIT KUMAR
Re: HOW TO SELECT SINGLE BLOCK OPTION IN KMOTIONCNC
You might read this.
Hi tom,
i tried the above method that you told above,
i am getting this error while compiling and running the program.
How to resolve this error?tcc: undefined symbol 'ScreenScript'
Thank You
AMIT KUMAR
AMIT KUMAR
Hi Amit,
You must not have included the file with the ScreenScript function.
Hi tom ,
Which file you are referring ??
which file to include?
for (;;)
ScreenScript("WinMsg:DlgName;IDC_SingleStep;BM_CLICK;");
Delay_sec(0.5);
Thank You
AMIT KUMAR
AMIT KUMAR
KflopToKMotionCNCFunctions.c should contain the ScreenScript function. Does it? What Version are you using?
