Disable Gamepad while ESTOP
HowHardCanItBe
Post by HowHardCanItBe » Thu Oct 08, 2020 8:20 pm
When the ESTOP is pressed in, a Gamepad jog (user error) disables the drives (yellow DROs). Is there any way to temporarily disable the Gamepad (while ESTOP is in)? I tried setting m_EnableGamePad=0 in GCodeConfigCNC.txt while the ESTOP is in, but the checkbox remains checked.
On this machine, the ESTOP is hard wired to the PMDX/Geckos. If the ESTOP is released prior to making a Gamepad jog (no user error), everything works fine.
Thanks.
Re: Disable Gamepad while ESTOP
Post by TomKerekes » Thu Oct 08, 2020 9:40 pm
You might try setting the Jog Speed Overrides to zero, and then back to 1 when EStop is released.
	DoPCFloat(PC_COMM_SET_JOG_OVERRIDE_X, 0.0);
	DoPCFloat(PC_COMM_SET_JOG_OVERRIDE_Y, 0.0);
	DoPCFloat(PC_COMM_SET_JOG_OVERRIDE_Z, 0.0);
HowHardCanItBe
Post by HowHardCanItBe » Fri Oct 09, 2020 3:09 am
Thanks again!
Besides those six Jog Speeds fields (X,Y,Z,A,B,C), can any of the other fields on the Tool Setup Screen | Trajectory Planner page be overridden (just curious)? I looked in the <>\DSP_KFLOP\PC-DSP.h file, but didn't see any Constants for the other fields.
Post by TomKerekes » Fri Oct 09, 2020 4:30 pm
No, just the commands listed in PC-DSP.h are available.
