I am using KFLOP+KONNECT+KANALOG for connecting FRO i.e. the Hexadecimal switch which has 5 input pins and 16 position based on the 5 input pins.
I have connected the all 5 input pins for Hexadecimal switch to konnect pin number 1040,1041,1042,1043,1044. I want to set each position out of 16 position to use FRO 0 to 1.6.
How to proceed with the programs for checking 5 pins at each FRO change. ? how can i check the 5 pins for one input of FRO.
Waiting for your kind reply.
FRO AND RRO USING HEXADECIMAL SWITCH
AmitKumar171
Thank You
AMIT KUMAR
AMIT KUMAR
Re: FRO AND RRO USING HEXADECIMAL SWITCH
Hi Amit,
A hexadecimal switch should normally require 4 bits not 5.
Does the switch return gray code or binary?
If gray code you might do something like:
int grayToBinary(int num)
unsigned int temp = num ^ (num>>4);
temp ^= (temp>>2);
temp ^= (temp>>1);
return temp;
float FRO=0.1f*grayToBinary(ReadBit(1040)*8+ReadBit(1041)*4+ReadBit(1042)*2+ReadBit(1043));
AmitKumar171
Hi tom ,
Thanks for your reply.
Help me with Binary code program.
Yes it requires 4 bits.A hexadecimal switch should normally require 4 bits
The switch returns binary codes.Does the switch return gray code or binary?
Thank You
AMIT KUMAR
AMIT KUMAR
Hi Amit,
The problem with binary is sampling bits while they are changing can give indeterminate values. For example changing from 7 to 8 might temporarily read 0 or 15. I think the same debounce function can be used to identify when things have changed and are stable. See below:
int hlast=0,hlastsolid=-1,hcount=0;
int Debounce(int n, int *cnt, int *last, int *lastsolid);
int hex;
float FRO;
for(;;)
// read hex value with potential glitches
hex = ReadBit(1040)*8+ReadBit(1041)*4+ReadBit(1042)*2+ReadBit(1043);
// "debounce" hex value
if (Debounce(hex,&hcount,&hlast,&hlastsolid)!=-1) // changed and stable?
FRO = hlast * 0.1f;
printf("FRO changed to %f\n",FRO);
// Debounce a bit
// return 1 one time when first debounced high
// return 0 one time when first debounced low
// return -1 otherwise
#define DBTIME 300
int v = -1;
if (n == *last) // same as last time?
if (*cnt == DBTIME-1)
if (n != *lastsolid)
v = *lastsolid = n; // return debounced value
if (*cnt < DBTIME) (*cnt)++;
*cnt = 0; // reset count
*last = n;
return v;
}Regards,
AmitKumar171
Hi tom,
THanks for your reply, will check that and update.
Thank You
AMIT KUMAR
AMIT KUMAR
