create a c program to run axes.
irmad
Re: create a c program to run axes.
Post by irmad » Tue Sep 08, 2020 4:27 pm
What are the uses of VAR?
and how, in one program g code there are 2 files?
Post by TomKerekes » Tue Sep 08, 2020 5:14 pm
Hi irmad,
what causes the DAC to oscillate on CH0 and CH1?
Are you referring to dither? You might read this.
can i put a value of 0 on the dead band range and dead band gain?
See this.
velocity in the previous configuration, I set 700, does kmotioncnc automatically calculate when in kmotioncnc? if i want speed at g code F2100 (2100mm / min = 35mm / s).
If KMotionCNC is configured properly and in mm mode then F will be in mm/min
See here and here.
To easily switch between files. Please don't use KMotion.exe's GCode Screen. It is obsolete. Use KMotionCNC instead.
irmad
Post by irmad » Tue Sep 08, 2020 5:41 pm
why when testing at kmotion.exe, it is very accurate, but when running with kmotionCNC is not accurate, the difference is 1-2 mm.
What is wrong ?
irmad
Post by irmad » Wed Sep 09, 2020 1:30 pm
I do not understand how to fill / rate this. please show me how.
Post by TomKerekes » Wed Sep 09, 2020 5:09 pm
What is wrong ?
What are you doing in KMotion.exe and what are you doing in KMotionCNC.exe? What "difference" are you referring to?
See here. You can get to a explanation of any parameter yourself with just 2 mouse clicks: click Help, click the parameter
irmad
Post by irmad » Wed Sep 09, 2020 7:24 pm
about axis parameter:
for example in kmotion I use V = 700, A = 3500, J = 350000. what value should I set in KmotionCNC for the Axis parameter?
does it have to follow the value in kmotion.exe?
irmad
Post by irmad » Wed Sep 09, 2020 7:39 pm
[/quote]
I mean, for multiple g code files in 1 program.
Can it ? and how?
Post by TomKerekes » Thu Sep 10, 2020 8:44 pm
see here.
Can it ? and how?
No, a GCode Program is one file.
irmad
Post by irmad » Thu Sep 24, 2020 2:29 pm
Sir, I still can't make the pedal function as a Cycle Start command, and halt. I want pedal number 1 (bit 137) when Normaly Close is Cycel Start, and when Normaly Open is Halt. can you write down the C program, so that I copy it in my C program.
Post by TomKerekes » Thu Sep 24, 2020 10:51 pm
Hi irmad,
The ExternalButtons.c example has such an example of having an external input trigger Cycle Start. If you can't figure it out we offer personal programming support for a fee. Contact our support if you are interested. We charge $250/hr with a 2 hr minimum.
