BigThread7 compiles and loads OK, but when I execute it there is no console print. If I comment out the array definition and change to a different printf, it works.
I could not see any obviously bad addresses in the load.
Attached linker files. I'll download the latest release and try it out.
SJH
What would cause direct FPGA I/O to break?
Re: What would cause direct FPGA I/O to break?
- linkerfiles.zip
- (5.05 KiB) Downloaded 230 times
PS:
I did notice there are some comments in cload_cinit() which are tagged with 'tktk':
if (temp == 0) // tktk skip 0 length pads
Stepping through with the debugger, I did notice that temp would in fact be zero every other time through the main loop of that function. Not sure how that's supposed to work, but from a naive perspective I would not have expected it to take that branch so often.
SJH
SJH
Found this thread re TI:
https://e2e.ti.com/support/tools/ccs/f/81/t/454222
So I added
i = i+7 & ~7; // SJH - align to 8
at the bottom of the loop in cload_cinit() and (lo and behold) it fixes my problem loading the supervisor. So I guess you should try it out on Windows too!
SJH
So I added
SJH
SJH,
You're a genius! It works in Windows also and allows your .out file to load and run in V4.33q. Will add to the next release.
