axis resolution
ZooBDoo
axis resolution
Post by ZooBDoo » Tue Dec 10, 2019 8:48 pm
I'm a bit confused about the configuration page relating to axis resolution and velocity and how the C program motion, Step response, KCNC trajectory planner and jog speeds interplay. Are they consistent with each other?
AZ
Re: axis resolution
Post by TomKerekes » Tue Dec 10, 2019 9:22 pm
Hi AZ,
Please read this wiki article and let us know if you still have questions.
cnc_freak
Contact:
Re: axis resolution
Post by cnc_freak » Wed May 27, 2020 8:57 pm
I read the article but i have still a question about a servo installation. For example if i want the max motor revolutions to be 1500rpm, and the servo drive/motor gives 1024 counts/rev, what should i but in the velocity parameter.
Re: axis resolution
Post by TomKerekes » Wed May 27, 2020 9:18 pm
1500 / 60 x 1024 = 25600 counts/sec
cnc_freak
Contact:
Re: axis resolution
Post by cnc_freak » Wed May 27, 2020 10:20 pm
The servo drive gives an incremental output A,/A, B, /B. Does not Kflop read that x 4? So that kflop read every rev 1024 x 4 = 4096?
Re: axis resolution
Post by TomKerekes » Thu May 28, 2020 12:31 am
That's always confusing. It depends on whether the 1024 is quadrature cycles (sometimes referred to as "lines") or quadrature counts. You said counts so I assumed quadrature counts. If I'm wrong the result will be obvious so multiply by 4.
