RTCP 5 axis machine
Re: RTCP 5 axis machine
Post by TomKerekes » Sun Jan 12, 2020 5:19 pm
Hi Igor,
Ignore my last post. I am able to reproduce the problem. The problem only occurs if the GViewer screen is open.
Please give me some time to troubleshoot the problem.
Igor
Post by Igor » Sun Jan 12, 2020 5:25 pm
Отключить KFLOP USB
Переименовать C: \ KMotion435b -> C: \ KMotion435bxxx
Установить KMotion435b
Удалить C: \ KMotion435b \ KMotion \ Release \ GCodeInterpreter.dll
Скопируйте новый GCodeInterpreter.dll в папку C: \ KMotion435b \ KMotion \ Release
Щелкните правой кнопкой мыши C: \ KMotion435b \ KMotion \ Release \ GCodeInterpreter.dll | Свойства | Разблокировать
Безопасность Windows | Настройки защиты от вирусов и угроз | Защита в реальном времени | от
Дважды щелкните C: \ KMotion435b \ KMotion \ Release \ KMotionCNC.exe
сообщить, что происходит
the program is not loaded. Window appears for 3 seconds and closes
Post by TomKerekes » Sun Jan 12, 2020 6:13 pm
Hi Igor,
My mistake, changing the GGodeInterpreter.dll interface required updating other files.
Please re-download and copy these 5 patched files to the C:\KMotion435b\KMotion\Release folder:
KMotionDLL.dll
KMotion.exe
KMotionCNC.exe
KMotionServer.exe
Igor
Post by Igor » Sun Jan 12, 2020 6:46 pm
good work, I thank! But there are still questions
Post by TomKerekes » Sun Jan 12, 2020 7:13 pm
Hi Igor,
That would be normal if you have a KStep.
What boards do you have?
Please post your Initialization C Program.
Igor
Post by Igor » Sun Jan 12, 2020 7:29 pm
I more often indicated my configuration, only step motors .
Post by TomKerekes » Mon Jan 13, 2020 4:54 pm
Hi Igor,
Do you drive the step motors with KStep or something else?
If you don't have KStep make sure you don't have this line in your C Program:
Igor
Post by Igor » Tue Jan 14, 2020 4:55 pm
KStepPresent=TRUE; // enable KSTEP input multiplexing---This row has been deleted and the blinking problem persists.
here file of initialization
InitStep6AxisSpindleAxis5.7z
(1.83 KiB) Downloaded 358 times
.he is a worker?
Kinematics5AxisTableAGimbalB
PivotToChuckLength = 3.208661 //inches (81.5mm)- Changing values I do not see changes in the simulation test program
Post by TomKerekes » Tue Jan 14, 2020 5:12 pm
Hi Igor,
The file you posted still has KStepPresent=TRUE;
You won't see any difference in the GCode Viewer Plot. It shows the XYZ path of the GCode.
Start with something very simple such as a line or point with one angle change.
Also your code doesn't turn on RTCP with G43.4 Hxxx
Attach the GCode
Igor
Post by Igor » Tue Jan 14, 2020 5:28 pm
hi Tom. there is a screen. the line is absent. My postprocessor displays code like this. He won 't work?
