Heater connected on Knozz Nozz FET is not working after some time
AmitKumar171
Post by AmitKumar171 » Fri Nov 22, 2019 5:55 am
Hi tom ,
I am using Knozz for powering up Bed heater as well as Nozz Heater for my printing head and bed respectively.
I am using 1000k thermistor that is calibrated to reach a temperature of upto 285 degree C.
And bed thermistor is also 1000k thermistor that is also calibrated for reaching temperature upto 150 degree C.
The issue i am facing is heater is not heating sometimes when it is heated by command M100 P280 Q150.
In my case i am also connecting external 3 50w heater to heat the bed more also, some of that heat is also absorbed by nozzle heater too.
So sometimes nozzle heater stops working. Bed heater is working fine.
How to resolve this issue ? , i want to connect both bed and nozzle heater and run them simultaneously.
When i check the counts and voltage as well as led indicator in kflop is also showing voltage, and sufficient counts are applied, voltage is also coming, LED indicator of nozzle heater is also glowing but nozzle heater temperature is not increasing. Temperature is stuck sometimes at 80, 150 etc.
Please suggest approprate solution to this problem.
Thank You
AMIT KUMAR
Re: Heater connected on Knozz Nozz FET is not working after some time
Post by TomKerekes » Fri Nov 22, 2019 9:39 pm
Hi Amit,
What voltage do you measure across the nozzle heater element? What nozzle heater power supply voltage are you using?
AmitKumar171
Post by AmitKumar171 » Tue Nov 26, 2019 5:59 am
Hi tom,
Thanks for your reply.
I am measuring 11.89V at nozzle heater element.
I am using 12V nozzle power supply.
Waiting for your kind reply.
Thank You
AMIT KUMAR
Post by TomKerekes » Tue Nov 26, 2019 4:44 pm
Hi Amit,
If full supply voltage is on the heater element what else are you expecting?
