Cycle Counter
DMSdesignco
Cycle Counter
Post by DMSdesignco » Tue Oct 22, 2019 11:49 pm
Hello Everyone,
I would like to add a cycle counter to the KMotionCNC screen. Ideally it would have a zero reset button and a display to show cycles run since last reset.
Thanks for any and all suggestions,
David.
Re: Cycle Counter
Post by TomKerekes » Wed Oct 23, 2019 12:06 am
Hi David,
Are you using the KMotionCNC Screen Editor?
DMSdesignco
Re: Cycle Counter
Post by DMSdesignco » Mon Oct 28, 2019 4:29 pm
Yes we are using the KMotion Screen Editor.
David.
Re: Cycle Counter
Post by TomKerekes » Mon Oct 28, 2019 5:44 pm
Hi David,
You might add a DROLabel to your screen such as shown here in red.
Configure it to monitor Var 162 for a string to display as shown here:
Now create a C Program to increment a persist Variable Counter and display it on the screen. We use Var 50 for the counter.
#define COUNT_VAR 50 // declare what Variable to use as a counter
    char s[80];
    persist.UserData[COUNT_VAR]++;  // count
    // Now Format as string
    sprintf(s,"%d",persist.UserData[COUNT_VAR]);
    // Put it onto the Screen
    DROLabel(1000, 162, s);
Another C Program to Clear the count
    char s[80];
    persist.UserData[COUNT_VAR]=0;  // cleat count
Then call the Count Program when you want it to increment. For example you might have M30 (end of Job do a count)
You might also add a User Button that executes the ClearCount.c Program to Clear the counter
ClearCount.c
(447 Bytes) Downloaded 1364 times
Count.c
(441 Bytes) Downloaded 1249 times
DMSdesignco
Re: Cycle Counter
Post by DMSdesignco » Fri Nov 01, 2019 12:15 am
Thanks very much for your guidance. I will build one tomorrow when I have access to one of our machines.
That was a BIG help!
David.
DMSdesignco
Re: Cycle Counter
Post by DMSdesignco » Mon Nov 18, 2019 3:39 pm
Just a quick post to let you know the screen counter is awesome and our customers love it.
Thanks very much for your help with this!
Best regards,
David.
Re: Cycle Counter
Post by TomKerekes » Mon Nov 18, 2019 5:58 pm
Hi David,
Great! Thanks for taking the time to post back.
