How can I start up???
Hello Dynomotion team ;
I am writing forum turkey istanbul.
I am a new user. I getted Klof board. I don t Know Where can I startup.
I have two project.
1. CNC milling 4 axis and tool change 24tool. ( retrofit First brand cnc milling machine) (Taiwan Brand)
2. CNC lathe c axis and turret tool change 12 station ( Retrofit Traunb Tnd 400 C axis cnc lathe) (German Brand)
I would work first cnc milling machine.
I want to ask more general question.
1. Kflop board can connect plc with rs 232 or Rs485 More input for automation.??
2. How can I more button input on control panel??. ( for example start stop mdı single block light coolled auto hand whell)
3. I dont know to C program how can I made my custom automation??
4. How can I to enter encoder feed back from servo drive??. ( Closed loop)
5. Kflop board can work without pc? independent controller??.
Best regard.
I hope I haven't opened the subject in the wrong place
I have two project.
Best regard.
Royal Tech.
Re: How can I start up???
Hi cnytbsk,
It would be simpler to add more Inputs using one or more of our Konnect Boards.
That is possible. KFLOP itself has a 3.3V UART. See here for more information. Also see the examples in the \C Programs\RS232\ folder.1. Kflop board can connect plc with rs 232 or Rs485 More input for automation.??
See the ExternalButtons.c example. For MPG see the wiki here.2. How can I more button input on control panel??. ( for example start stop mdı single block light coolled auto hand whell)
You will need to learn C. You don't need to be an expert. See the section here on Programming in C. Also see here. See a Tool Changer Example here.3. I dont know to C program how can I made my custom automation??
See here to determine what type of encoder signals you have.4. How can I to enter encoder feed back from servo drive??. ( Closed loop)
KFLOP has some stand-alone capability, but basically no. If your application requires: Disk storage, Display, Keyboard, Mouse, GCode Interpreter, more complex Trajectory Planning, or Kinematics a PC is required.5. Kflop board can work without pc? independent controller??.
Hello Mr Tom
I had to take a break for health reasons. I'm fine now. I ordered three cards. Kflop, Kanalog, Konnect. I only got the kflop card from customs. I did not get other two cards. I have a only kflop card now.
First of all, I can run the pulse direction servo motor drive with this card. ( Without Kanalog Boards)
Application of three axis milling. I installed kmotion on my computer.
I don't know how to use it?
Royal Tech.
Hi cnytbsk,
And the KStep Tutorial here.
Most likely yes depending on the Step/Dir input voltage and timing specifications of your Drives. See here.First of all, I can run the pulse direction servo motor drive with this card. ( Without Kanalog Boards)
You will need to be more specific about what you don't know. You might watch this video and also the tutorial below. The overall steps are similar whether you have a KStep or other types of Step/Dir drives.I don't know how to use it?
Hi tom
Many thank for fast reply.
I added Foto my board.
https://photos.app.goo.gl/RnWkSfAQf9jBjNEP9
I will check all..
I will check all..
Royal Tech.
I really didn't understand.
I'm going to try to understand or find someone to support me because it's incredibly complicated. maybe it's hard for the first time I met
If I don't find anybody, I'm gonna get back to you.
make a visual step by step and try it that way.
Royal Tech.
Hello Tom.
I looking up to some one But I didn t find
I disaded, ı will prepare drawing paper about my problem. Because I can find solve with basic drawing. English is not my native language and I understand visually
kmotion and board connected. Kmotion / Consel / Send / Send / Send / Send / Send / Send after I readed ready.
I will do easy connection on made table with basic stepper drive and motor for traning ( After I will use servo drive and motor / spindle motor)
I add external pc power. JR1 ( not J3 Dont use)
Wiring for Stepper motor.
JP 7 PN No: 16 DIR CH0
JP 7 PN No: 15 PUL CHO
JP 7 PN NO: 1 vcdd +3.3v (We need +5volt. Can I use PN NO:23 vcdd5v)
How can I wiring e stop ? and Kmotion side?
I don't have background on topic. thank for patience
BEst Regards..
BEst Regards..
Royal Tech.
Hi cnytbsk,
Yes JP7 Pins 23 and 24 have +5VJP 7 PN NO: 1 vcdd +3.3v (We need +5volt. Can I use PN NO:23 vcdd5v)
There is no direct support for EStop. Its up to you to decided exactly what you would like to happen. Normally it is best to wire it externally in hardware. It can also be connected to any input and it can be monitored by a User C Program and perform any operation you desire. Below is the example called EStopDisablesAll.c which monitors Input Bit 180 and when active disables 3 axes.How can I wiring e stop ? and Kmotion side?
// Watches for EStop Input and disables Axes when detected
for (;;) //loop forever
// if ESTOP present disable any enabled Axis ??
#define ESTOP_BIT 180
if (ReadBit(ESTOP_BIT))
if (ch0->Enable) DisableAxis(0); // axis still enabled? - Disable it
if (ch1->Enable) DisableAxis(1); // axis still enabled? - Disable it
if (ch2->Enable) DisableAxis(2); // axis still enabled? - Disable it
Hi Tom.
I added my problem. I readed pdf. I m not connected Kflop. ( I try, 12 days not working )
I prepare owm 3 axis puls dir c program. ( for stepper motor).
I watched many time kstep KSTEP Introduction - (Getting Started with KSTEP Stepper Driver)
Where can write per step ( I realdy don t undertand that)? I know acceleration and velocity.
Thanks for e stop c program
I dont understand
which connector suitable for it ? JP ?
PİN Number? (I don't understand how to map bit 180 to pin)
how it should wring?
Many thanks
I dont understand
Many thanks
Royal Tech.
I don't understand what you are doing or showing. It seems communication is working and you have V4.34. So I don't understand what problem you are trying to solve. When you reboot KFLOP it is normal to lose communication. You should not need the Serial COM Port Driver.I added my problem. I readed pdf. I m not connected Kflop. ( I try, 12 days not working )
I don't understand the question. You can set the axis resolution of counts/inch in KMotionCNC | Tool Setup | Trajectory Planner | Axis Parameters. Note for a stepper system counts=steps.Where can write per step ( I realdy don t undertand that)? I know acceleration and velocity.
Bit 180 is on KStep. I don't think you have a KStep. If you only have a KFLOP then you must interface to a KFLOP 3.3V input. It is up to you to know basic electronics. One possibility is to switch a KFLOP Input with a pull down resistor to 3.3V. For example KFLOP JP4 Pin 5. This would be IO BIt 16. See JP4 described here.Thanks for e stop c program
I dont understand
