File operations (fopen, fscanf, fprintf, etc)
AntonKulikov
Post by AntonKulikov » Tue Aug 13, 2019 12:11 pm
Hello!
Where can I find detailed information regarding operations with text files?
What is "wt", "rt", "r+" etc.
What parameters of the fopen, fscanf, fprintf commands can generally take values
How can I navigate the lines of a file, go to the beginning or end, insert an empty line, select and replace characters... etc.
I can not find this information anywhere.
Thanks for the answer
Re: File operations (fopen, fscanf, fprintf, etc)
Post by TomKerekes » Tue Aug 13, 2019 6:13 pm
Hi Anton,
See KMotionDef.h for available KFLOP functions, variables, and definitions. Here is an excerpt:
typedef int FILE;
FILE *fopen(const char*, const char*);		   // Open a text file for writing on the PC 2nd param = "rt" or "wt" or "at"(append write text mode)
int fprintf(FILE *f, const char * format, ...);		   // Print formatted string to the PC's Disk File
int fclose(FILE *f);                           // Close the disk file on the PC
#define MAX_READ_DISK_LENGTH 1024 // max allowed length of disk file line length
char *fgets(char *str, int n, FILE *file); //read string from PC disk file, str=buffer, n=buffer length, f=FILE pointer, returns NULL on error
int fscanf(FILE *f, const char *format, ...); //read sting from PC Disk file, convert values, returns number of items converted
int feof(FILE *f);   // End of file status for disk reading
KFLOP support for accessing files on the PC is very basic. Only text mode (not binary) is supported. Only:
rt - read file text mode
wt - write file text mode
at - append to file write mode
please see the KMotionDef.h file. For formatting codes Google these functions to find many on-line explanations. Such as:
https://en.wikipedia.org/wiki/Printf_format_string
https://en.wikipedia.org/wiki/Scanf_format_string
You would need to do such things yourself by reading the file line-by-line and then writing a new file line-by-line.
AntonKulikov
Post by AntonKulikov » Thu Aug 15, 2019 10:16 am
Wow! I did it! Thank you very much! :)
But could you tell me if it is possible to obtain the following information in any format (for subsequent recording to a file):
1) Current time
2) Program execution time
3) The name of the executable program file (<program1.tap> for example)
Thanks for the answers, Tom!
Post by TomKerekes » Thu Aug 15, 2019 4:07 pm
Hi Anton,
1) Current time
Not currently. Time_sec() returns seconds from power up.
You can monitor JOB_ACTIVE to determine when a Job starts and how long it has been running.
Not currently
AntonKulikov
Post by AntonKulikov » Fri Aug 16, 2019 5:58 am
It is very, very sad...
After all, we can see in the window title bar both the file name and the program execution time.
Thus, no report on the production process using KMotion is impossible to do ...
And the active state JOB_STATUS also appears when changing a hand tool, for example.
Okay, I can think of something with the runtime of the program, but with the rest ...
Thanks Tom!
Post by TomKerekes » Fri Aug 16, 2019 5:23 pm
There is already a <>\KMotion\Data\RunLog.txt file written by KMotionCNC that has Time, Job Time, and Filename that looks like:
Mon, Aug 12, 2019, 04:09:07 Elapsed Job Time: 95.3 sec C:\KMotionSrc\GCode Programs\turbothisthread.ngc
Mon, Aug 12, 2019, 04:11:32 Elapsed Job Time: 18.9 sec C:\KMotionSrc\GCode Programs\turbothis thread no G95.ngc
AntonKulikov
Post by AntonKulikov » Mon Mar 02, 2020 12:33 pm
But I do not see AM&PM time in this file. And it is very unpleasant ...
Post by TomKerekes » Mon Mar 02, 2020 5:52 pm
Hi AntonKulinkov,
Oops. You are correct. We can offer a patch to use 24 hr format. We'd prefer that as adding AM/PM may break Code of existing Users. Does that work for you?
