dolphin CAM post help processor needed
turbothis
Re: dolphin CAM post help processor needed
Post by turbothis » Wed Jul 24, 2019 9:56 pm
man, i have spent a couple hours trying all kinds of different info in there and cant get that little arc to reverse with no luck
tricky little bastard
turbothis
Post by turbothis » Wed Jul 24, 2019 11:17 pm
does kmotioncnc accept something in I K code
N11G03X0.5514Z-5.5909I0.1198K0.129
N12G02X0.56Z-5.5952I-0.0112K-0.0153
or in this radius code??????????????????????????????????????????????????????? :arrow: :arrow: :arrow: :arrow: :arrow: ????????????? lol
N130 G02 X0.262 Z-0.519 R0.019
N140 G01 X0.262 Z-0.6114
N150 G02 X0.2598 Z-0.6204 R0.019
turbothis
Post by turbothis » Thu Jul 25, 2019 12:28 am
jeez the more i read on this i may be doomed.
turbothis
Post by turbothis » Thu Jul 25, 2019 1:16 am
is there a sample code for the lathe function that i can dabble with?
turbothis
Post by turbothis » Thu Jul 25, 2019 4:43 am
ok i found out the issue.
the post processor for some reason gets G02 and G03 switched!
how in the code can this be adjusted to switch the G02 and G03 output?
TITLE:
	:T1 = {
		CNC Lathe
			Mach3 Radius Mode Post
			G32 type threading
			Modified by Steve Blackmore 06/04/05
	:T2 = {
			Added Mach3 Constant surface speed support 30/01/05
			Added G83 peck drilling 02/03/05
			New tool format support added 27/07/05
			Altered M6 to follow tool select 24/12/05
END:
VERSION:
        FILEVERSION 11.0 TURNING
END:
WORDS:
	:TMP = {DDDDDD.dd}
	:BLOCK = {"N"DDDD" "}
	:XAXIS = {"Z"DDDDD.ddd" "} {"Z"DDD.dddd" "}
	:YAXIS = {"X"DDDDD.ddd" "} {"X"DDD.dddd" "}
	:XARC = {"K"DDDDD.ddd" "} {"K"DDD.dddd" "}
	:YARC = {"I"DDDDD.ddd" "} {"I"DDD.dddd" "}
	:ARAD = {"R"DDDDD.ddd" "} {"R"DDD.dddd" "}
	:DELAY = {"G04 P"DDD" "}
	:DWELL = {"P"DDDD.dddd" "}
	:PECK = {"Q"DDDDD.ddd" "} {"Q"DDD.dddd" "}
	:NDEEP = {"Q"DDDDD.ddd" "} {"Q"DDD.dddd" "}
	:RPLANE = {"R"DDDDD.ddd" "} {"R"DDD.DDDD" "}
	:FEED = {"F"DDDDD.dddI" "} {"F"DDD.dddd" "}
	:SPIN = {"S"DDDD" "}
	:TOOL = {"T"ZDD}
	:SUBPR = {"P"DDDD" "}
	:REPEAT = {"L"DDDD" "}
	:CRC = {"D"DD" "}
	:TLC = {""ZDD" "}
	:SURF = {"S"DDDD" "}
        :SRAD = {"R"DDDD.ddI} {"R"DD.ddddI}
	:INDEX = {"INDEX"DDD.ddd" "}
	:PROGNO = {"O"DDDDD" "}
	:NUM1 = {" "DDDD.dddd" "}
	:ROT = {" "DD" "}
	:TOOLD = {DDDDD.ddd} {DDD.dddd}
END:
AXES:
	YSCALE		1
        XSCALE		1
	TURRET
END:
GROUPS:
	:G1 = {G00_ G01_ G02_ G03_ G80_ G81_ G82_ G83_ G83.1_ G84_ G85_ G86_ G87_ G88_ G89_}
	:G2 = {G17_ G18_ G19_}
	:G3 = {G90_ G91_ G90.1_ G91.1_}
	:G5 = {G48_ G93_ G94_ G95_ G96_ G97_}
	:G6 = {G20_ G21_}
	:G7 = {G40_ G41_ G42_}
	:G8 = {G43_ G49_}
	:G10 = {G98_ G99_}
	:G12 = {G50_ G51_ G54_ G55_ G56_ G57_ G58_ G59_ G59.1_ G59.2_ G59.3_}
	:G13 = {G61_ G61.1_ G64_}
	:G4 = {M00_ M01_ M02_}
	:G7 = {M03_ M04_ M05_}
	:G8 = {M07_ M08_ M09_}
	:G9 = {M48_ M49_}
END:
CYCLES:
     	NPECK       CANNED
	NDEEP       CANNED
	TURN	    EXPAND
	FACE	    EXPAND
        THREAD	    EXPAND
END:
MACROS:
	#N = {
		$BLOCK:BLOCK
		; If the block number reaches the max (according to RD274) start over
		; Note: 'N' has no meaning in processing and is there for readability ONLY
		IF ($BLOCK EQ 99990) THEN
			SET $BLOCK = 5
		ENDIF
	#L = { [RAPID ? (G01_) / (G00_)]  }
	#FTYPE = { [FEEDTYPE ? (G94_) / (G95_) ] }
	#X = { $X:XAXIS }
	#Y = { $Y:YAXIS }
	#I = { $XCEN:XARC }
	#K = { $YCEN:YARC }
	#AR = { $ARCRAD:ARAD }
	#R = { ($CCLDIST:RPLANE) }
	#P = { IF ($CDELAY NE 0) THEN ($CDELAY:DWELL) ENDIF }
	#F = { [RAPID ? [FEEDTYPE ? ($FPM:FEED) / ($FPR:FEED)] ] }
	#DWELL = { IF ($CDELAY NE 0) THEN (G82_) ELSE (G81_) ENDIF }
	#RAPID = { SET [RAPID] = 2 }
	#FEED = { SET [RAPID] = 1 }
	#SPIN =  { ($SPINDLE:SPIN) [SPIN ? (M05_) / (M03_) / (M04_) ] }
	#SURF =  { IF ( $SURF GT 1) THEN
                   $SURF:SURF
               ELSE "S525"
               ENDIF
	#GCLW = {
		IF ($USR11 EQ 0) THEN
			(G02_)
		ELSE
			(G03_)
		ENDIF
	#GACLW = {
			(G03_)
		ELSE
			(G02_)
		ENDIF
	#IPLANE = {
		IF ([CRETRACT] EQ 2) THEN
			(G99_)
		ELSE
			(G98_)
		ENDIF
	#CRC = {
		; Only output G41/G42 if part surface is requested (PSPROG=2) which means the CNC
		;  has to offset the tool
		IF ([PSPROG] EQ 2) THEN
			[CUTCOM ? (G40_) / (G41_) / (G42_) ]
		ENDIF
	#CRCNO = {
			($CRCNO:CRC)
		ENDIF
  #Q = { ABS($CDEPTH/$CNDEPTH):NDEEP }
	#Q = { ABS($CDEPTH/$CNDEPTH):NPECK }
	#UNSET = {
		IF ((ABS($DELTAX) LT $USR8) AND (ABS($DELTAY) LT $USR8)) THEN
			UNSETALL
		ENDIF
END:
RULES:
	:INIT = {
		set $RAPIDFEED = 100	 ; rapid feedrate
		SET $USR11 = 0 ; Set to 1 if Proturn Arcs to be negated (dependant on tool)
		SET $USR12 = 0 ; set for Arc direction fix for FRONT turret and TURN cycles.
		SET $USR13 = 1.0 ; SCALE FACTOR TO COMPENSATE FOR ANGLES BEING WRONGLY SCALED IN INCH.
		SET $USR14 = 0.0
	:START = {
		; start with N10, increment in 1s
		SET $BLOCK = 1
		set $INCR = 1
	:ORIGIN = {
		;#N (G92_) $ORIGINY:YAXIS $ORIGINX:XAXIS EOB
                ;unset :XAXIS
		;unset :YAXIS
	:RETRACT = { #N #L #Y #X EOB }
	:UNITS = {
		; G20/G21 = Inch/MM units
		; G18 = XZ Plane
		; G64 = Constant velocity mode (G61 = exact stop)
		; G80 = Cancel modal motion (deactivates all move modalities)
		; G90 = Absolute mode (G91 = Incremental mode)
		; M49 = Disable speed/feed overrides
		#N [UNITS ? (G21_) / (G20_)] (G18_) (G64_) (G80_) (G90_) (M49_) "G90.1 "
		; KAA - changed order to default IN so that the set is not needed 2x for each IN
		; Sets MIN change in move for a program block to be written
		SET $USR8 = 0.00005		; default IN scale
		set $usr13 = 25.4
		IF ([UNITS] EQ 1) THEN
			SET $USR8 = 0.0005	; set MM scale
			SET $USR13 = 1.0
		ENDIF
		(G40_) (G49_) (G80_) EOB
		#N #FTYPE #F EOB
	:CUTCOM = {
			IF (0 NE 0) THEN
			ELSE
				(G40_)
			ENDIF
			#CRCNO EOB
		ENDIF
	:GOTO =
		NULL ; "DISTANCE : " $DISTANCE:NUM1 EOB
		IF ($DISTANCE GE $USR8) THEN
			#N #CRC #CRCNO EOB
			#N #L #Y #X #FTYPE #F EOB
		ENDIF
	:GOCLW = {
		#UNSET
		IF (([PSPROG] NE 2) OR ([CUTCOM] LT 2)) THEN
			#N #CRC EOB
			#N #GCLW #Y #X #AR #F EOB
		ELSE
			#N #CRC #CRCNO EOB
		ENDIF
	:GOACLW = {
		#UNSET
			#N #CRC EOB
			#N #GACLW #Y #X #AR #F EOB
		ELSE
			#N #CRC #CRCNO EOB
		ENDIF
	:DELAY = { #N $DELAY:DELAY EOB }
	:NDEEP = { #N (G83) #Y #X #R #Q #IPLANE #F EOB }
	:NPECK = { #N (G83.1) #Y #X #R #Q #IPLANE #F EOB }
	:SCREWING = { 	#N "G32 " #Y #X #F EOB
		UNSET (G5)
		UNSET :FEED
	:SCRCUT = {
            	UNSET :FEED
		#N #FTYPE #F EOB
	       	#N (G0_) #X #Y EOB
		#N (G1_) $CXSTART:XAXIS $CYSTART:YAXIS EOB
		#N (G76_) ($CYEND-$CDEPTH):YAXIS $XEND:XAXIS ""$FEEDANGLE:PA " "$PITCH:FS " "$ROUGHCUTS:DS " "$FINISHCUTS:PF " T0 " $SPINDLE:SPIN ""$CLDIST:PO eob
		#N (G94_)eob
      		UNSET :FEED
	:SPINDLE = {UNSET (G5)
        	IF ( [SPIN] eq 1) then
        	    	#N (M05) eob
        	ENDIF
        	IF ([SPINTYPE] EQ 2 ) THEN
        		#N [SPIN ? NULL / (M03_) / (M04_) ] #FTYPE #F EOB
			#N (G48_) $MAXSPIN:SPIN " " EOB
			#N (G96_) $SURF:SURF EOB
        	ELSE
			#N (G97_) $SPINDLE:SPIN " " EOB
        	ENDIF }
	:FINISH = { #N (M05_) (M09_) EOB
			#N (M30_) EOB " " EOB }
	:SELCTL = {
		SET $USR11 = 0
		IF ([TURRET] EQ 2) THEN
			SET $USR12 = 1     ; Front Turret, set $USR12 for TURN cycles arc direction
			SET $USR12 = 0
		ENDIF
		set $CYCLETIME = $CYCLETIME + 0.5 ; 30 seconds for a tool change
			#N (M09_) EOB
	        	#N "G00"" " $YSAFPOS:YAXIS $XSAFPOS:XAXIS (M05_) EOB
		IF ($X NE $XTLOAD ) THEN
			#N (G28_) $XTLOAD:XAXIS EOB
			#N (G49_) EOB
		ELSE
		IF ($Y NE $YTLOAD ) THEN
			#N (G28_) $YTLOAD:YAXIS EOB
			#N (G49_) EOB
		ENDIF
		ENDIF
		EOB
			#N (G49_) EOB
	:CYCLEOFF = {
		#N (G80_) EOB
		unset :G1
		UNSET(M08_)
		UNSET:RPLANE
		UNSET(M09_)
		UNSET :FEED
		UNSET:YAXIS
		UNSET:XAXIS
		UNSET (G5)
		UNSET :SPIN
		UNSET :PECK
		UNSET :DWELL
	:GOHOME = {
		UNSET (G5)
		UNSET :FEED
		UNSET :SPIN
		#N "G00" " " $YSAFPOS:YAXIS $XSAFPOS:XAXIS #FTYPE #F EOB
END:
turbothis
Post by turbothis » Thu Jul 25, 2019 4:54 am
jeez!
i swapped these go2 and go3's
#GCLW = {
			(G02_)
		ELSE
			(G03_)
		ENDIF
	#GACLW = {
			(G03_)
		ELSE
			(G02_)
		ENDIF
seems to work fine now but i will try it out more in the morning
