Is this right that the pwm mode used by Snapamp is a current loop mode when I select an axis with ouput DC BRUSH MOTOR, so, the max value under the step responses can be 1000 max ?
Is it possible to drive the output with a normal pwm mode instead of the current mode (as it is possible by entering pwm / pwmc command line) with max values 255 ?
I am trying to modelise the controller under matlab/simulink, but I have no information about the functionnal design of the pwm current loop mode... Do you have some functionnal diagram wich can help me to implement this in matlab/simulink to modelise that ?
I already make some measurement on my motor (back emf, inertia, etc...) and currently my simulation under simulink work with a PID wich drive a pwm 0-100% in voltage mode to drive my motor, but if snapamp only use current loop mode, I would like to implement this in my design...
Thanks you very much for your support.
Regards.
PWM mode used in snapamp for driving a DC brushed motor
Re: PWM mode used in snapamp for driving a DC brushed motor
Hi rdpdo2002,
PWM = (Commanded Current - Measured Current) x Gain
The default Gain = 16 This is computed every PWM cycle at 32.55KHz
The Currents are 10-bit values + sign and the PWM is an 9-bit value + sign
Yes but it is actually 1023 = 35AmpsIs this right that the pwm mode used by Snapamp is a current loop mode when I select an axis with ouput DC BRUSH MOTOR, so, the max value under the step responses can be 1000 max ?
It would be possible using a C Program to output to the PWM. The max value is actually 511.Is it possible to drive the output with a normal pwm mode instead of the current mode (as it is possible by entering pwm / pwmc command line) with max values 255 ?
The current loop is simply proportional gain where:I am trying to modelise the controller under matlab/simulink, but I have no information about the functionnal design of the pwm current loop mode... Do you have some functionnal diagram wich can help me to implement this in matlab/simulink to modelise that ?
