Hay Tom,
So i tried to use Quadrature mode and just got growling. Then i switch back to Step/Dir mode and got very rough movement in one direction and would continue in that direction when axis should be returning back to start with much more growling of motor.
So after chasing my tail and checking wiring i think i have a faulty drive. Did several tests with each motor and encoder on both drives and have eliminated the cables,motors and encoders.
At one point the Z axis drive started giving good green plots, then i let it sit idle for about 2 or 3 minutes and plots started to get worse on each test movement and motor started to growl, particularly in one direction. This also happened when i would connect the X axis to Z axis drive.
So i switched to the X axis drive and kept same configs in Kmotion, results where 100 times better, literally, at one point i was getting an error of .0003". When i started it was around .0015".
But even the X axis Drive had issues when set resolution of 8000(Gear Number 2000 and Line Number 2000). The good test below was drive resolution set to 2000.
Here is a plot showing things going to crap for no reason.This is a average of how the bad plots would look,some made no sense at all...
Here is a good one...
Also attached is plot file. Did not really try any fine tunning yet, but still got good results.
Will do some more sanity tests tomorrow to double check everything i did. Will post back.
Troy
