Snap-amp stepper configuration
Posted: Mon Mar 11, 2019 5:05 am
I accidentally deleted tbe configuration on one of my machines and it’s been years since I’ve messed with configuration on it. I have not been able to find a document describing the setup.
I vaguely recall that axis resolution in the trajectory planner is not as simple as just multiplying 200 steps by the ratio of the drive mechanism. Was there something to do with the number 50? Does 50 equal a full revolution on the motor instead of 200?
Are the PID settings used at all?
It looks like sometimes the axis will simulate the oscillations in a servo system. Can I make it stop this?
In manual command entry I’ve noticed that when I do a G0 it doesn’t stop very close to the destination. But if I issue slower command with a G1 it will get closer but still not exact unless there is another command following it.
