NOELNOG
Post by NOELNOG » Mon Jan 13, 2025 5:16 pm
Hi Tom
Is there a function to watch the value of the axes read outs, for example when performing tool change, if the X axis moves 70 inches near magazine, do the next step and continue, but if for any reason the axes doesn't get to 70 inches the tool change operation must stop, is any function to add to the atc c. program for that?
regards
Post by TomKerekes » Mon Jan 13, 2025 9:03 pm
Hi Noel,
Its not clear what you are trying to achieve. Normally if you command an axis to move you will wait until it is completed.
Do you have encoders? If so and the axis doesn't move properly you should get a following error.
You can monitor the commanded position in counts as ch->Dest and the actual Position as ch->Position.
