Kflop Cannot enable Axis
men8ifr
Post by men8ifr » Mon Nov 06, 2023 9:17 am
I'm just setting up my Kflop - I installed the latest Kmotion software 2 days ago - when I go into the axis selection and click to enable axis 0 I briefly see a tick and then a fraction of a second later it dissappears - it has switched the axis off.
I looked at the help but see no reference to tnot being able to enable an axis.
What could stop me enabling an axis?
I have another laptop with an older version (probably 2+ years old) and that works as expected
Kflop is connected when I try - otherwise you get messages Kflop is not connected (as expected)
I checked all other axis do the same as well.
Everything else appears to work as it should.
My Set-up
PM30 Milling Machine - 3 axis
Kflop
Leadshine copy closed loop 'hybrid' stepper drivers similar to HBS86
Nema 34 6A 8.5Nm motors with encoder (encoder connects to stepper driver)
Fusion 360 Software
men8ifr
Re: Kflop Cannot enable Axis
Post by men8ifr » Mon Nov 06, 2023 3:14 pm
To add to this when I start Kmotion I get the error ---------------------------
KMotion
Error Status Record Size mismatch
Disable further status updates?
Yes No
Maybe this is related.
Also from the IO window I cannot select any bits as outputs
My Set-up
Kflop
Fusion 360 Software
Post by TomKerekes » Mon Nov 06, 2023 5:29 pm
The Firmware Version Flashed in KFLOP and the KMotion Version must match. Answer Yes to disable status updates, flash New Version, then re start KFLOP and KMotion.exe.
