Hello, i have a problem with konnection my Kflop to Mach3. In plugin menu of Mach3 there is no Dynomotion plugin so i cant config it, but if look in Mach3 plugin folder - its installed. Besides at first time after instalation Kmotion over my Mach3 i choose prefer control device as Kmotion Init, but when i try to reload mach3 by presing reset button comes error (photo adding).
At these moment, I want to test a kflop board with Mach3 without motors, its possible?
I want to make sure how it works and what need to be config on Mach3+Kflop.
I working on rebuilding old soviet union lathe. And electric cabinet with all stuff in assembley stage.
Before all components on lathe was programed in VB Script language that understand Mach3 and worked on chinese controller.
But from past few month i decided to change old controller board on kflop. So i as i said before, all i need at these moment its to plugin kflop board to my laptop and try to understand how it works and config special on my needs.
I cant understand what i did wrong? I have working Mach3 version, have Kflop board where installed KMotion434. I use stock InitStepDir3Axis config file, what uploaded to Kflop. Mach3 see dynomotion plugin, but when i pressed reset button comes error. What needs to do to figured out?
I designed special screenset to Mach3 for my lathe and want to work with stack: Mach3 + Kmotion.
Please help.
Mach3+Kflop
Re: Mach3+Kflop
Hi Goodwin,
Mach3 is obsolete and unsupported. Consider using our free KMotionCNC instead. It also has a Screen Editor.
Strange. Please try our Later Test Version here. What Version of Mach3 are you using. What Version of Windows?In plugin menu of Mach3 there is no Dynomotion plugin so i cant config it
That indicates it is using the Dynomotion Plugin. The Plugin must be configured to use the Init Program you create.when i try to reload mach3 by presing reset button comes error (photo adding).
Yes. If axes are configured as open loop step/dir then nothing will know whether there are motors or not.I want to test a kflop board with Mach3 without motors, its possible?
