Stepper Hybrid - JP7 vs JP5
nice_kflop
Re: Stepper Hybrid - JP7 vs JP5
Do I have to adjust encoder into kflop or does the wiring look right
You don’t have any encoder signals going to KFLOP. No encoder data is going to KFLOP. How do you expect KFLOP to know the encoder position? Magic?
Set the input modes of your axes to “No Input”
nice_kflop
You can not set KFLOP to Closed Loop as there is no position feedback going to KFLOP. KFLOP is blind to any errors and must operate in an open loop manner. How could it correct errors if it doesn't know what the error is?
The drive is supposedly closed loop. I couldn't find any manual for it. But it appears to have an Alarm Output. You might interface that to KFLOP so that if there is an alarm KFLOP will be aware and be able to do something such as stop.
nice_kflop
This drawing is all i found for the driver. Does this mean I use a digital ground pin for ALARM- and use a general purpose 5v tolerant like IO2 for ALARM+, then under limit switch options>>under positive>> i select bit no. 2
Drawing also shows it may need a resistor
or maybe not!
Please correct me dunno how to do it.
That should work.This drawing is all i found for the driver. Does this mean I use a digital ground pin for ALARM- and use a general purpose 5v tolerant like IO2 for ALARM+
No this is an Alarm not a Limit switch. Your C Program should monitor the Input and do something such as disable all axes when it occurs.then under limit switch options>>under positive>> i select bit no. 2
Yes you will need a pull up resistor. Even with 5V tolerant pins pulling above 3.8V should be avoided. I'd use a 470 Ohm pull up to 3.3V.Drawing also shows it may need a resistoror maybe not!
Note connecting the GND COM to KFLOP GND will likely defeat the opto isolation between KFLOP and the Drive. It would be better to connect through an Opto Isolated Input such as provided by our Konnect board or other device.
