Motor Direction
bill.nelson
Motor Direction
Hello. I am controlling a water jet machine with Kflop and SnapAmp. I have everything working, except the x-axis motor is turning the wrong direction (if I jog positive, the x-axis moves negative). I am using brushed DC motors. How can I reverse the direction to correct this problem? I have not been able to find a software setting to do this.
dynomotion
- Site Admin
Re: Motor Direction
For Brushed DC Motors its simplest to reverse the motor leads to reverse the drive direction. You will also need to reverse the direction of the Encoder Feedback. For that you can change the sign of the InputGain0 parameter.
bill.nelson
Re: Motor Direction
Great! Thank you so much! This worked
