Gaming control set up
Hotrodjohn
Post by Hotrodjohn » Fri Apr 19, 2019 7:15 pm
I plugged in a Logitech 310 gaming control. My question is are there any set up options or it just is what it is? I can’t seem to find touch off z and one of the buttons causes a disconnect loosing x y z.......
Re: Gaming control set up
Post by TomKerekes » Fri Apr 19, 2019 7:25 pm
Hi Hotrodjohn,
The Gamepad should work as described here. There aren't any configurable options without changing the KMotionCNC Source Code. I'm not sure why you would get a disconnect. What is your configuration? What button are you pushing?
Hotrodjohn
Post by Hotrodjohn » Fri Apr 19, 2019 10:16 pm
I guess it’s the emergency stop on the left. So no touch off z available on controller?
Post by TomKerekes » Fri Apr 19, 2019 10:21 pm
That should disable the axes not disconnect.
Not without changing the KMotionCNC Source Code.
