Tool radius compensation on G18
cemoa9
Post by cemoa9 » Thu Mar 31, 2022 5:31 pm
A great improvement would to get tool radius compensation working on lathes so with G18. Sure CAM softs can generate a correct toolpath without this feature activated, but for some applications CAM may be just much slower / complicated / not optimized.
Cordially,
Francois
Re: Tool radius compensation on G18
Post by TomKerekes » Fri Apr 01, 2022 9:51 pm
Hi Francois,
We will consider this.
But does it make sense? Are lathe tools typically round?
cemoa9
Post by cemoa9 » Sat Apr 02, 2022 4:18 pm
Inserts have a radius, if not taken into account (in CAM or Radius compensation when manual programming) then the curves, chamfers (every shape which is not following only X or Z) are not matching the program.
Cordially
Francois
cemoa9
Post by cemoa9 » Wed Apr 13, 2022 9:55 am
Does it make sense to you?
Cordially,
Francois
Post by TomKerekes » Thu Apr 21, 2022 11:13 am
Hi Francois,
Yes. Looks somewhat difficult to add. You might look at the code to see if there is an easy way to add.
