idk why lathe changes
Re: idk why lathe changes
Post by TomKerekes » Mon Mar 04, 2024 1:40 am
No :)
You've included CSSJog.c and also pasted its contents. Only Include it.
You have 2 main() functions. There must only be one. main() is where the program starts. There can be only one starting place for a program.
Code is incorrectly indented making it hard to understand or read. Use Auto Indent to clean it up.
turbothis
Post by turbothis » Tue Mar 05, 2024 11:16 pm
gotcha
Can grounding the E stop from the servo amp to the electronics case bring in noise?
getting some nice run off on Z axis in the Z negative direction only
even after the MaxFollowingError=5000 trips
X axis works great
turbothis
Post by turbothis » Tue Mar 05, 2024 11:22 pm
anything else i should do to the init or is it runnable for spindle turning?
#include "MySpindleDefs.h"
#include "CSSJog.c"
int main() {
    // X axis
	ch0->InputMode=ENCODER_MODE;
	ch0->Vel=80000;
	ch0->Accel=5e+07;
	ch0->Jerk=5e+07;
	ch0->P=5;
	ch0->I=0;
	ch0->D=20;
	ch0->FFAccel=0;
	ch0->FFVel=0;
	ch0->MaxI=200;
	ch0->MaxErr=200;
	ch0->MaxOutput=2000;
	ch0->DeadBandGain=1;
	ch0->DeadBandRange=0;
	ch0->InputChan0=0;
	ch0->InputChan1=0;
	ch0->OutputChan0=0;
	ch0->OutputChan1=0;
	ch0->MasterAxis=-1;
	ch0->LimitSwitchNegBit=0;
	ch0->LimitSwitchPosBit=0;
	ch0->SoftLimitPos=1e+09;
	ch0->SoftLimitNeg=-1e+09;
	ch0->InputGain0=1;
	ch0->InputGain1=1;
	ch0->InputOffset0=0;
	ch0->InputOffset1=0;
	ch0->OutputGain=1;
	ch0->OutputOffset=0;
	ch0->SlaveGain=1;
	ch0->BacklashAmount=0;
	ch0->BacklashRate=0;
	ch0->invDistPerCycle=1;
	ch0->Lead=0;
	ch0->StepperAmplitude=250;
	ch0->iir[0].B0=1;
	ch0->iir[0].B1=0;
	ch0->iir[0].B2=0;
	ch0->iir[0].A1=0;
	ch0->iir[0].A2=0;
	ch0->iir[1].B0=1;
	ch0->iir[1].B1=0;
	ch0->iir[1].B2=0;
	ch0->iir[1].A1=0;
	ch0->iir[1].A2=0;
	ch0->iir[2].B0=1;
	ch0->iir[2].B1=0;
	ch0->iir[2].B2=0;
	ch0->iir[2].A1=0;
	ch0->iir[2].A2=0;
    // Z axis
	ch1->InputMode=ENCODER_MODE;
	ch1->Vel=80000;
	ch1->Accel=5e+07;
	ch1->Jerk=5e+07;
	ch1->P=10;
	ch1->I=0;
	ch1->D=20;
	ch1->FFAccel=0;
	ch1->FFVel=0;
	ch1->MaxI=200;
	ch1->MaxErr=200;
	ch1->MaxOutput=2000;
	ch1->DeadBandGain=1;
	ch1->DeadBandRange=0;
	ch1->InputChan0=1;
	ch1->InputChan1=0;
	ch1->OutputChan0=1;
	ch1->OutputChan1=0;
	ch1->MasterAxis=-1;
	ch1->LimitSwitchOptions=0x114;
	ch1->LimitSwitchNegBit=11;
	ch1->LimitSwitchPosBit=0;
	ch1->SoftLimitPos=1e+09;
	ch1->SoftLimitNeg=-1e+09;
	ch1->InputGain0=1;
	ch1->InputGain1=1;
	ch1->InputOffset0=0;
	ch1->InputOffset1=0;
	ch1->OutputGain=1;
	ch1->OutputOffset=0;
	ch1->SlaveGain=1;
	ch1->BacklashAmount=0;
	ch1->BacklashRate=0;
	ch1->invDistPerCycle=1;
	ch1->Lead=0;
	ch1->MaxFollowingError=5000;
	ch1->StepperAmplitude=250;
	ch1->iir[0].B0=1;
	ch1->iir[0].B1=0;
	ch1->iir[0].B2=0;
	ch1->iir[0].A1=0;
	ch1->iir[0].A2=0;
	ch1->iir[1].B0=1;
	ch1->iir[1].B1=0;
	ch1->iir[1].B2=0;
	ch1->iir[1].A1=0;
	ch1->iir[1].A2=0;
	ch1->iir[2].B0=1;
	ch1->iir[2].B1=0;
	ch1->iir[2].B2=0;
	ch1->iir[2].A1=0;
	ch1->iir[2].A2=0;
	    // A  axis / spindle
	ch2->InputMode=ENCODER_MODE;
	ch2->Vel=300000;
	ch2->Accel=80000;
	ch2->Jerk=150000;
	ch2->P=10;
	ch2->I=0;
	ch2->D=10;
	ch2->FFAccel=0;
	ch2->FFVel=0;
	ch2->MaxI=200;
	ch2->MaxErr=1e+06;
	ch2->MaxOutput=2000;
	ch2->DeadBandGain=1;
	ch2->DeadBandRange=0;
	ch2->InputChan0=2;
	ch2->InputChan1=0;
	ch2->OutputChan0=2;
	ch2->OutputChan1=0;
	ch2->MasterAxis=-1;
	ch2->LimitSwitchNegBit=0;
	ch2->LimitSwitchPosBit=0;
	ch2->SoftLimitPos=1e+30;
	ch2->SoftLimitNeg=-1e+30;
	ch2->InputGain0=-1;
	ch2->InputGain1=1;
	ch2->InputOffset0=0;
	ch2->InputOffset1=0;
	ch2->OutputGain=1;
	ch2->OutputOffset=0;
	ch2->SlaveGain=1;
	ch2->BacklashAmount=0;
	ch2->BacklashRate=0;
	ch2->invDistPerCycle=1;
	ch2->Lead=0;
	ch2->StepperAmplitude=20;
	ch2->iir[0].B0=1;
	ch2->iir[0].B1=0;
	ch2->iir[0].B2=0;
	ch2->iir[0].A1=0;
	ch2->iir[0].A2=0;
	ch2->iir[1].B0=1;
	ch2->iir[1].B1=0;
	ch2->iir[1].B2=0;
	ch2->iir[1].A1=0;
	ch2->iir[1].A2=0;
	ch2->iir[2].B0=1;
	ch2->iir[2].B1=0;
	ch2->iir[2].B2=0;
	ch2->iir[2].A1=0;
	ch2->iir[2].A2=0;
	EnableAxis(0);
    EnableAxis(1);
    EnableAxis(2);
	DefineCoordSystem(0,-1,1,-1);
turbothis
Post by turbothis » Wed Mar 06, 2024 9:31 pm
ok i got the spindle performing well
the only issue is i have to double push the CW/CCW buttons to work
which ever button i push first is the way it will rotate. (first push does nothing but pick which way to rotate)
the second time i push one of the buttons it will turn on spindle. ( this can be either CW or CCW as the first button push locks in which direction to rotate)
my CW
int   *css_mode = &persist.UserData[PC_COMM_CSS_MODE];			// Mode 1=Normal RPM mode. 2=CSS
	float speed = *(float *)&persist.UserData[SPEEDVAR];  // value stored is actually a float
	int LastState = persist.UserData[STATEVAR];  // get last state
	if (CS0_axis_a == -1 && !ch2->Enable)		// is A axis not defined in the Coordinate System and not enabled?
		EnableAxis(2);			// yes, enable the axis
	if (LastState==-1)
		// if spindle was CCW now we want CW
		// spin down
		ClearBit(SPINDLECW_BIT);
		ClearBit(SPINDLECCW_BIT);
		Jog(SPINDLEAXIS,0);
	// turn spindle on CW and ramp to new speed
	SetBit(SPINDLECW_BIT);
	LastState = 1;          														 //  Add string
	if (*css_mode != 2)
		if (USE_POS_NEG_VOLTAGE)
			Jog(SPINDLEAXIS,speed * FACTOR * LastState);
		printf("Jogging Spindle %f counts/sec\n",speed * FACTOR);
	persist.UserData[STATEVAR] = 1;  // remember we are CW
my CCW
	if (LastState==1)
		// if spindle was CW now we want CCW
		// spin down
		Jog(SPINDLEAXIS,0);
	// turn spindle on CCW and ramp to new speed
	SetBit(SPINDLECCW_BIT);
	LastState = -1;
	if (*css_mode != 2)
	persist.UserData[STATEVAR] = -1;  // remember we are CCW
my jog
	float speed = *(float *)&persist.UserData[KMVAR];  // value stored is actually a float
	persist.UserData[SPEEDVAR] = persist.UserData[KMVAR];  // Always save the last desired speed
	if (LastState==0 || *css_mode == 2)
		// if spindle is off (or CSS mode) and User Changes the speed
		// just save the desired speed
		return 0;
my off
	// spin down
	Jog(SPINDLEAXIS, 0);
	printf("Jogging Spindle Stop\n");
	persist.UserData[STATEVAR] = 0;	// remember we are Off
	while (!CheckDone(SPINDLEAXIS));
	if (CS0_axis_a == -1)		// is A axis not defined in the Coordinate System?
		DisableAxis(2);			// yes, disable the axis, otherwise leave it enabled
turbothis
Post by turbothis » Wed Mar 06, 2024 11:02 pm
sigh....
so i just tried some other C code examples that did the same double push thing
i re-load my own ones i posted above and now it works perfect
this is what blows my mind. :?
i am about to get a go pro camera and film what happens
turbothis
Post by turbothis » Fri Mar 15, 2024 12:18 am
ok, i got another used AMC drive ( 250$ ebay ) and the Z axis works as it should again!
everything works.
stoked
Post by TomKerekes » Fri Mar 15, 2024 6:53 am
Congrats you are persistent.
turbothis
Post by turbothis » Sat Mar 16, 2024 12:59 am
i take pride in completion.
