CH2 powers up but does not function or turn off
turbothis
Post by turbothis » Tue Jul 23, 2019 11:15 pm
so i got 2 identical servo's wired up for CH0 and Ch1 ( X and Z axis ) Z axis works pretty much perfect
1 everything off, no programs open
2 turn power on to servo drives and CH1 immediately holds position ( CH1 does not hold with no KFLOP input, only when connected )
3 run my master arm program and all 3 axis find position normally
// Home and set the commutation for a 3 phase brushless motor // that is driven using two DAC Outputs // // Phase rotates until index mark is located and Encoder Zeroed
// Function definitions
// x must be in the range 0->1 returns sin(x) and sin(x+120 degrees)
float Sine3PH (float x, float *sin2);
// put a voltage v on a 3 Phase motor at specified commutation angle
void Write3PH_DACs(CHAN *chx, float v, double angle_in_cycles);
// return fractional part of a huge number accurately
float fractionf(double v);
// Main function entry point
                float k=0,A=500;   // set coil current amplitude DAC units
                double p0;
        // Z axis
    ch0->InputMode=ENCODER_MODE;
	ch0->OutputMode=NO_OUTPUT_MODE;
	ch0->Vel=400000;
	ch0->Accel=10000000;
	ch0->Jerk=200000000;
	ch0->P=1;
	ch0->I=0;
	ch0->D=20;
	ch0->FFAccel=0;
	ch0->FFVel=0;
	ch0->MaxI=200;
	ch0->MaxErr=1e+006;
	ch0->MaxOutput=2000;
	ch0->DeadBandGain=1;
	ch0->DeadBandRange=0;
	ch0->InputChan0=0;
	ch0->InputChan1=0;
	ch0->OutputChan0=1;
	ch0->OutputChan1=0;
	ch0->MasterAxis=-1;
	ch0->LimitSwitchOptions=0x0;
	ch0->SoftLimitPos=1e+030;
	ch0->SoftLimitNeg=-1e+030;
	ch0->InputGain0=1;
	ch0->InputGain1=1;
	ch0->InputOffset0=0;
	ch0->InputOffset1=0;
	ch0->OutputGain=1;
	ch0->OutputOffset=0;
	ch0->SlaveGain=1;
	ch0->BacklashAmount=0;
	ch0->BacklashRate=0;
	ch0->invDistPerCycle=-0.0004;
	ch0->Lead=0;
	ch0->MaxFollowingError=1000000;
	ch0->StepperAmplitude=20;
	ch0->iir[0].B0=1;
	ch0->iir[0].B1=0;
	ch0->iir[0].B2=0;
	ch0->iir[0].A1=0;
	ch0->iir[0].A2=0;
	ch0->iir[1].B0=1;
	ch0->iir[1].B1=0;
	ch0->iir[1].B2=0;
	ch0->iir[1].A1=0;
	ch0->iir[1].A2=0;
	ch0->iir[2].B0=1;
	ch0->iir[2].B1=0;
	ch0->iir[2].B2=0;
	ch0->iir[2].A1=0;
	ch0->iir[2].A2=0;
        // X axis
    ch1->InputMode=ENCODER_MODE;
	ch1->OutputMode=NO_OUTPUT_MODE;
	ch1->Vel=400000;
	ch1->Accel=10000000;
	ch1->Jerk=200000000;
	ch1->P=1;
	ch1->I=0;
	ch1->D=20;
	ch1->FFAccel=0;
	ch1->FFVel=0;
	ch1->MaxI=200;
	ch1->MaxErr=1e+006;
	ch1->MaxOutput=500;
	ch1->DeadBandGain=1;
	ch1->DeadBandRange=0;
	ch1->InputChan0=1;
	ch1->InputChan1=1;
	ch1->OutputChan0=2;
	ch1->OutputChan1=3;
	ch1->MasterAxis=-1;
	ch1->LimitSwitchOptions=0x0;
	ch1->SoftLimitPos=1e+030;
	ch1->SoftLimitNeg=-1e+030;
	ch1->InputGain0=1;
	ch1->InputGain1=1;
	ch1->InputOffset0=0;
	ch1->InputOffset1=0;
	ch1->OutputGain=1;
	ch1->OutputOffset=0;
	ch1->SlaveGain=1;
	ch1->BacklashAmount=0;
	ch1->BacklashRate=0;
	ch1->invDistPerCycle=0.0004;
	ch1->Lead=0;
	ch1->MaxFollowingError=1000000;
	ch1->StepperAmplitude=20;
	ch1->iir[0].B0=1;
	ch1->iir[0].B1=0;
	ch1->iir[0].B2=0;
	ch1->iir[0].A1=0;
	ch1->iir[0].A2=0;
	ch1->iir[1].B0=1;
	ch1->iir[1].B1=0;
	ch1->iir[1].B2=0;
	ch1->iir[1].A1=0;
	ch1->iir[1].A2=0;
	ch1->iir[2].B0=1;
	ch1->iir[2].B1=0;
	ch1->iir[2].B2=0;
	ch1->iir[2].A1=0;
	ch1->iir[2].A2=0;
        // A  axis / spindle
	ch2->InputMode=ENCODER_MODE;
	ch2->OutputMode=NO_OUTPUT_MODE;
	ch2->Vel=  300000;
	ch2->Accel=100000;
	ch2->Jerk= 2000000;
	ch2->P=10;
	ch2->I=0;
	ch2->D=20;
	ch2->FFAccel=0;
	ch2->FFVel=0;
	ch2->MaxI=200;
	ch2->MaxErr=1e+006;
	ch2->MaxOutput=2000;
	ch2->DeadBandGain=1;
	ch2->DeadBandRange=0;
	ch2->InputChan0=2;
	ch2->InputChan1=2;
	ch2->OutputChan0=5;
	ch2->OutputChan1=4;
	ch2->MasterAxis=-1;
	ch2->LimitSwitchOptions=0x0;
	ch2->SoftLimitPos=1e+030;
	ch2->SoftLimitNeg=-1e+030;
	ch2->InputGain0=-1;
	ch2->InputGain1=1;
	ch2->InputOffset0=0;
	ch2->InputOffset1=0;
	ch2->OutputGain=1;
	ch2->OutputOffset=0;
	ch2->SlaveGain=1;
	ch2->BacklashAmount=0;
	ch2->BacklashRate=0;
	ch2->invDistPerCycle=0.0003662109375;
	ch2->Lead=0;
	ch2->StepperAmplitude=20;
	ch2->iir[0].B0=1;
	ch2->iir[0].B1=0;
	ch2->iir[0].B2=0;
	ch2->iir[0].A1=0;
	ch2->iir[0].A2=0;
	ch2->iir[1].B0=1;
	ch2->iir[1].B1=0;
	ch2->iir[1].B2=0;
	ch2->iir[1].A1=0;
	ch2->iir[1].A2=0;
	ch2->iir[2].B0=1;
	ch2->iir[2].B1=0;
	ch2->iir[2].B2=0;
	ch2->iir[2].A1=0;
	ch2->iir[2].A2=0;
                // rotate until we find the index mark
                // Use f0 and f1 and f2 to flag when index found for ch0 and ch1 and ch2->
                // Break out when both indexes found (f0=1 and f1=1 and f2=1)
                ch0->Enable=FALSE;
                ch1->Enable=FALSE;
                ch2->Enable=FALSE;
                int f0,f1,f2;		// Index found flags
				f0=0;f1=0;f2=0;		// Set all to index not found
                for (;;)		//Indefinite loop
				if (f0==1 && f1==1 && f2==1) break;		// Done if all indexes found
                   if (f0==0)				// If Ch0 index not found
                                    Write3PH_DACs(ch0,A, ++k/10000.0);  // move the pole
                                    if (ReadBit(36))  // check for index mark ch0
                                                p0=ch0->Position; // Index found so save position
                                                ch0->Position=0;  // set current position to Zero
                                                ch0->CommutationOffset = 600;  // from auto phase find
                                                printf("Position ch0 = %f\n",p0);
                                                f0=1;		// Mark as ch0 index found
                                    }  // End readbit
                   }  // End if f0=0
                   if (f1==0)				// If Ch1 index not found
                                Write3PH_DACs(ch1,A, ++k/10000.0);  // move the pole
                                if (ReadBit(37))  // check for index mark ch1
                                                p0=ch1->Position; // Index found so save position
                                                ch1->Position=0;  // set current position to Zero
                                                ch1->CommutationOffset = 225;  // from auto phase find
                                                printf("Position ch1 = %f\n",p0);
                                                f1=1;		// Mark as ch1 index found
                                    }  // End readbit
                         }  // End f1=0
                    if (f2==0)				// If Ch2 index not found
                                Write3PH_DACs(ch2,A, ++k/10000.0);  // move the pole
                                if (ReadBit(38))  // check for index mark ch2
                                                p0=ch2->Position; // Index found so save position
                                                ch2->Position=0;  // set current position to Zero
                                                ch2->CommutationOffset = 1920;  // from auto phase find
                                                printf("Position ch2 = %f\n",p0);
                                                f2=1;		// Mark as ch2 index found
                                    }  // End readbit
                         }  // End f2=0
                    }  // End for loop
                EnableAxisDest(0,0.0f);  // Enable servo at destination of 0   Z axis
                EnableAxisDest(1,0.0f);  // Enable servo at destination of 0   X axis
                EnableAxisDest(2,0.0f);  // Enable servo at destination of 0   A axis
                DefineCoordSystem(1,-1,0,-1); // define which axes are in use
                // Loop forever outputting Servo output to dual DAC_SERVO_MODE
                for (;;)
                                if (ch0->Enable)  // if axis enabled commutate and output else command zero to DACs
                                                Write3PH_DACs(ch0,ch0->Output, (ch0->Position + ch0->CommutationOffset) * ch0->invDistPerCycle);
                                                Write3PH_DACs(ch0, 0.0,0.0);
                                if (ch1->Enable)  // if axis enabled commutate and output else command zero to DACs
                                                Write3PH_DACs(ch1,ch1->Output, (ch1->Position + ch1->CommutationOffset) * ch1->invDistPerCycle);
                                                Write3PH_DACs(ch1, 0.0,0.0);
                                 if (ch2->Enable)  // if axis enabled commutate and output else command zero to DACs
                                                Write3PH_DACs(ch2,ch2->Output, (ch2->Position + ch2->CommutationOffset) * ch2->invDistPerCycle);
                                                Write3PH_DACs(ch2, 0.0,0.0);
                }  // End for loop
} // End main()
                float theta,sin1f;
                if (angle_in_cycles<0)
                                theta = 1.0f-fractionf(-angle_in_cycles);
                                theta = fractionf(angle_in_cycles);
                DAC(chx->OutputChan0, (int)(v * Sine3PH(theta,&sin1f)));
                DAC(chx->OutputChan1, (int)(v * sin1f));
               }  // End Write3PH()
4 CH1 / X axis does not move by any command in Kmotioncnc ( button or MDI ) it does read position though
5 when i run the program from kmotion and hit "halt" CH0 and CH2 will disable but CH1 will not
6 when i run the program again but hit "stop" in kmotioncnc it will disable all the servos
picture of the trajectory plan
turbothis
Re: CH2 powers up but does not function or turn off
Post by turbothis » Tue Jul 23, 2019 11:21 pm
lolololol
ok well i changed this
ch1->invDistPerCycle=-0.0004;
and it works now
i swear i can try all day to problem solve but untill i8 post for help i cant figure it out
only when i spend time typing do i see the light......
