killed DAC outputs
Posted: Mon Jan 11, 2021 4:00 am
by Scott Pancheau
Figured out after I blew the DAC outputs that I had a ground voltage problem on drive. Is the 0 to 10v generated on the kanalog or from the kflop?
Don't know which one I need to order - or both?
Scott
Re: killed DAC outputs
Posted: Mon Jan 11, 2021 7:03 pm
Sorry to hear that Scott,
The +/-10V is generated on the Kanalog. Its hard to say if KFLOP was also damaged. If the other IO on Kanalog is still working then I would think it is likely that KFLOP was not damaged.
Posted: Wed Jan 13, 2021 2:40 am
by Scott Pancheau
Thanks Tom,
I will just order both,as I plan on retrofitting another machine later.
