Dear Tom,
Due to some reason, I need to modify my PC's IPv4 addresss to 192.168.1.200 to control another device.
But when I modify my IPAddress, the board can't be connected. It runs normally when the PC's IP address is automatic discovery.
What should I do?
Best regards,
Yuhu Li
03/15/2026
Konga connection problem
Re: Konga connection problem
Hi Yuhu,
If you are manually assigning IP Addresses then you will likely need to assign Kogna’s IP address to something like 192.168.1.201. See here.
