Help! PWM 0-10V.
Re: Help! PWM 0-10V.
Post by Lafayette » Mon Feb 12, 2018 9:21 am
I want to use to adjust the spindle speed
JP6 IO26 Gen Purpose PWM0 out
I want to use to turn the spindle on and off.
JP6 IO27 Gen Purpose LVTTL I/O 3.3V
I will connect the optopar to the flap, and from it I will connect to the servo amplifier at the input of the work permit(S-ON).
Pin 26 is connected to the converter that led you higher, it will be controlled by the speed 0-10V.
Sorry I don't understand. Do you have a friend who can communicate better in English?
Please respond to our previous questions and provide the requested information.
Hi...If you have a 12V power supply, you don't need rail to rail. An LM 358 or similar works fine if your filter has a fairly low cutoff. Using 16 bit PWM you can easily get the needed resolution. Here's what I've used. PWM freq is 1KHz. 5V input . The pot is to dial in 10V as the top end.
pcb assembly house
pcb assembly house
Hey Is it possible to control spindle motor speed with 0-10v DAC by sending analog signal to KFLOP board convereted by DAC while interfacing with Raspberry Pi, your suggestions will be helpful
Hi Grod45,
Sorry I don’t understand your question. KFLOP itself doesn’t have any Analog inputs. Normally you will need a PC running Windows.
MichaelMet
- Contact:
Help PWM 0 10V
Will do, I'll see if I can take some pictures as-well.
All I really need is a simple PWM driver, but I can't seem to get the code correct.
Just the pot that sets the duty cycle of a 16khz signal and that output to the fan, no feedback required....
Much simpler than the example here..is there a HEX file for that around?
-Nhilar
-Nhilar
Hi Nhilar,
Sorry I don't understand the issue.
You might look at the PWM1KHz.c example for a simple example to set a PWM value.
