Page 4 of 4
Re: 6 axis wire edm
Posted: Fri Nov 04, 2022 6:21 pm
Hi Guilherme,
If KFLOP can not communicate to KMotionCNC then you can't have KFLOP send an MDI command to KMotionCNC. You will have to do whatever you need to do entirely within KFLOP.
Re: 6 axis wire edm
Posted: Fri Nov 04, 2022 6:25 pm
by gui_marchioro
It does makes sense.
Thanks Tom.
Sincerely,
Guilherme
Re: 6 axis wire edm
Posted: Sun Nov 06, 2022 12:55 pm
by gui_marchioro
Just to make sure...
The WATCHDOG_DELAY defined in the example WatchdogStatusRequests.c as 5.0 can be set to any desired positive value without problems, right?
Sincerely,
Guilherme
Re: 6 axis wire edm
Posted: Sun Nov 06, 2022 4:27 pm
Hi Guilherme,
Yes it can, but realize that Windows is not a real time operating system. On rare occasions Windows/PC/USB may "freeze" momentarily. That is after all the whole purpose of KFLOP is to provide guaranteed deterministic real-time response so the PC doesn't have to. How long the worst case "freeze" will be depends on many things. So setting to less than around 1 second can run the risk of tripping the watch dog even when things are operating "normally".
Re: 6 axis wire edm
Posted: Wed Jun 07, 2023 8:19 am
by Rasta
hi Tom;
can you please tell me if its possible to edit the IDC_Bplus , IDC_Bminus , buttons so the arrow points in the same direction than the Z axis? instead of pointing left and right?
regards
Mariano
Re: 6 axis wire edm
Posted: Wed Jun 07, 2023 4:08 pm
Hi Mariano,
Yes use the
Screen Editor.
