Open Loop Command
Posted: Thu Sep 05, 2019 7:47 pm
We have a linear axis with linear scale position feedback driven by an analogue servo drive and brushless motor with velocity feedback using +/10 volt command input.
Our initial setup would be to adjust the amplifier volts/rpm so that 9 volts analogue command input = our desired maximum axis velocity as an open loop motion move.
How do you use the Step response screen to command an open loop motion profile move so that we can set the +/-10 volt servo amplifier speed reference before then closing the position loop using the KFlop and tuning using the PID gains ?
Tim
Tim
