Console Screen commands
Scott Pancheau
Post by Scott Pancheau » Thu Jan 21, 2021 8:20 pm
Is it possible to enter a distance move from the console to check counts per inch?
Scott
curtiskelowna
Re: Console Screen commands
Post by curtiskelowna » Thu Jan 21, 2021 8:47 pm
you could certainly use the "move" command. If you think it should be 100 cts/inch, send that and see if it actually is. why not just use the MDI in kmotion CNC?
I think the "linear" command can command the machine to move in actual units with the trajectory planner but I could be wrong
Scott Pancheau
Post by Scott Pancheau » Fri Jan 22, 2021 3:11 pm
Got it, thanks for your help.
Scott
