Axis Parameters - Cnts/inch
Posted: Wed Apr 22, 2026 12:40 am
Hi there,
In the Tool Setup Screen, in the Axis Parameters section, I'm noticing that when change the value for both X and Y by the same amount, the X & Y in the DRO are not showing the same newly updated distance.
For example, I first zero the DRO so that X and Y show 0. I then go into Axis Parameters and update both the X and Y to a new value, say 10300. When I look at the DRO I see that the X took on the distance change but the Y didn't, it only changed by 0.0007".
I'm I misunderstanding something?
Thank you in advance!
Cyprian
Cyprian
