Run from line / set next statement
Chevvron
Post by Chevvron » Mon Apr 13, 2026 10:51 am
Our special purpose 8 axis machine sets a temporary datum after probing for each bearer set of operations in G code.
At the end of each bearer a G52 Y0 clears the temporary Datum back to the absolute position to move to for the next bearer where the probing routine and G code operations are repeated again, all 40 to 50 times down the 52 metre Y axis.
If there is a need to stop the process mid bearer then you need to MDI G52 Y0 before using the set next statement so the Y axis knows tge absolute position to repeat that particular bearer.
Is there a way to edit or script the run from line so that the G52 Y 0 can be performed automatically rather than the operator having to remember to do MDI G52 Y0 ?
Also the scan to find the parameters for set next statement set the Z axis safe move feedrate too high.
It is scary to see the Z axis retract at 6 metres a minute when 1 metre a minute is preferred.
I know this can be manually edited but it is another operator intervention rather than default.
It would be good to have the set next statement overall scriptable / configurable.
Any suggestions ?
Tim
Re: Run from line / set next statement
Post by TomKerekes » Tue Apr 14, 2026 6:43 pm
Hi Tim,
I'm not sure I understand, but isn't there a way to write the GCode so G52 is not used for the absolute moves and therefore doesn't need to be set/cleared. For example set a fixture offset to run the local GCode. And one "zero" fixture offset for the absolute moves. Or use G53 to make the absolute moves?
Wouldn't the GCode contain the "G52 Y0" so the operator would set the line to that? Or is the code being set to the middle of some operations?
The move to safez is a rapid move rather than a feed move. The rapid velocities are set in KFLOP/Kogna. See here. Do you need to perform rapids in Z at high rates for other purposes? If not, you might reduce the Z Rapid rate.
