Home Position Machine Coords Offset
Posted: Thu Jan 22, 2026 9:29 pm
Thanks for the help with geometric correction over long axis travels late last year.
Last week we did a 50 metre error correction run in 250mm increments.
The error correction worked well.
We now the original Machine and the new on on tge same X axis track using the same X axis Machine coordinate system.
I have the new Kogna Machine homingvat the 50 metre end.
Is there a way to set the machine position and destination to 50 metres after homing as opposed to setting zero ?
Quite often we have 3 machines on the same X axis track with an individual machine homing at either end and the middle Machine homing in the ce tre but all machines using a common X axis machine coordinate system.
Tim
Tim
